Chassis Lubrication / Grease - Propeller Shaft / Spiders & Slide Yoke / Zerks
#136
Digging up an old thread to ask what is the difference between the spider and the double cardan joint? Don't both of those terms refer to a u joint? Is it saying to use lithium or moly for the u joint zerks?
#137
when properly greased should the slip joint area on the driveshaft be greasy/wet to the touch? pumped the slip joint about 10 times and stopped for fear of overfilling but the slip area is still bone dry to the touch.
just picked up a '13. first suv, new to the whole greasing driveshaft thing.
#138
drive around a bit and check on the slip area, if it gets covered with grease then you should be good, if not then do few more pumps. Overfilling will cause the slip joint to not compress freely.
I usually stick to around 10 pumps and do it every 10K miles
GXLUX (01-08-22)
#140
So I now have experienced the slip yoke thump/clunk on my '21 GX. "11,000 miles ) Have had it on my two '16 GX's. Easy fix---grease the slip yoke. Never heard clunks again.
Based on the latest TSB for 2019-2021GX's Acrad posted above, Toyota states "Do NOT grease/lubricate the propeller shaft slip yoke". Told dealer that their master mechanic had recommended and done that on both of my '16s. Says he contacted Toyota who advised him NOT to lube. He filed some kind of inquiry with Lexus and is waiting to hear back. What the heck is the difference on the19 to 21's?? This TSB has been out for over a year now, and no known fix? (BTW, this my only b*tch with any of my three GX 460's)
#141
#143
Great thread. I've been doing this on my 4Runners for years as the zerk placements are the same for the GX. As @Acrad mentioned it's much easier when the truck is up on jacks and you are doing a tire rotation. Throw it in neutral and simply move the wheels to get access to the zerks because I have never in all my years had the zerks all in a simple position to get my grease gun on them. Always one or two that are in the 12 o'clock position and makes it a b1tch to get to them.
One small detail I saw not being mentioned is to ensure you wipe the zerk off before you attach your grease gun. The zerk will pick up dirt and you don't want to push that dirt in while pumping grease in.
FWIW I've been using this https://www.amsoil.com/p/dominator-s...ng-grease-grg/ on all the zerks for all my 4Rs and GXs and Tacomas.
And on my 22 I do have the thump in the rear when the truck is cold taking off from a stop.... Didn't realize there was a TSB out on it. I'm going to grease the zerks in the coming days. Just turned 2K miles on the truck. Doesn't happen all the time, but definitely in the morning taking the dog for a walk going off from a stop I'll hear a dull thud in the back. Wife's 19 never heard that sound and I've greased the zerks in that truck a few times now.
Acrad (01-28-22)
#144
how many pumps do you add and what gun are you using?
#145
I purchased my grease gun off amazon back in 2014... still works like a champ.
Regarding volume of grease, the above comments in this thread already have great examples of folks describing how much grease they are putting into the zerks.
@Acrad posted this within the thread https://www.clublexus.com/forums/gx-...l#post10228777 for the pumps he uses.
Really not overly complicated. The hardest part if you do not have the truck on jacks will be getting the zerks lined up so you can easily get the grease gun on them.
#146
Is anyone using this Macnaught K32-01 grease gun? Looks pretty nice. The head is suspiciously similar to the Lincoln 1134 but the barrel is different. The Lincoln comes with a longer hose too, the Macnaught looks really short.
Just wondering how it performs and longevity. I need another grease gun and I'd prefer spending another $10 on something like this than an "import" pos that won't work half the time.
#147
Just greased mine this weekend. I put the car in neutral and slid under there to do the work. Not a lot of clearance but since it was in neutral I could grab the driveshaft and rotate as necessary to get at the zerks. The car moves back and forth as you turn it so it's a bit of effort but doable.
Next time I'll put it on some sections of 2x6 or something to gain a little height. Beats taking the time to put it up on stands.
william489 (11-02-22)
#148
Great topic - thank you for the wealth of info. Just took care of mine at 9000km (2nd oil change). Valvoline synthetic (grey tube), plus a LockNLube coupler. An easy, yet annoying job. Took a few tries to get some of the zerks aligned just right.
Acrad (05-01-22)
nuclearn8 (05-01-22)
#150
Hi! In my 2022 Lexus GX460's maitenance booklet there is a line item "
May I ask all pros on this forum to confirm it is true for 22 GX460 please? If that's true then the booklet is wrong. I suspect the service advisor was full of it.
- Lubricate Drive Shaft"
