Chassis Lubrication / Grease - Propeller Shaft / Spiders & Slide Yoke / Zerks
#181
Hi, couldn't agree more. I've been using the product since 2019. I migrated to Australia, I was happy that the is Lube Shuttle is available here in Australia, less waiting time an can be purchased online.
#182
I do 10-12 pumps on the slip yokes as well. On my stock height GX I use 2 pairs of these 12K lb Rhino ramps. They work well.
https://www.amazon.com/RhinoGear-119.../dp/B0117EETEK
I think HF has their own version now for $10 less for a pair.
Did I still pump too much grease into slip yokes? Is there anything I can do now to prevent possible damage?
#183
Looking for the right grease to use and noticed a change in manuals. For my 2022 and also the 2023. It only calls out to use only “Lithium base chassis grease, NLGI No.2” for Spider and Slide Yokes. I find that interesting, since 2021 and assuming prior years from all the threads I’ve been reading called out Moly for
the Slide Yoke. I’m wondering why the change?
Thinking of giving this a shot. Mobilgrease XHP 222
#184
They probably made the change for ease of maintenance so you only need one type of grease. I never say any park number changes. It makes life much easier not having to have 2 types of grease.
