Chassis Lubrication / Grease - Propeller Shaft / Spiders & Slide Yoke / Zerks
Old 06-27-19, 06:28 AM
  #61
Jmildoc
Jmildoc's Avatar
Just did this last night to my GX and my Tundra, super easy job, however if you are using the small grease tubes plan to reload cause they obviously dont hold very much. I should of posted some pics but just didnt think about it, maybe next time.
Old 09-30-19, 05:35 AM
  #62
lconroy
lconroy's Avatar
How many tubes of grease are people going through when doing this service?
Old 09-30-19, 08:11 AM
  #63
NTH
NTH's Avatar
One regular sized tube will last several drive shaft services for me. I only do 4-6 pumps each zerk.
Old 10-05-19, 10:58 AM
  #64
nebrou
nebrou's Avatar
Default Anyone knows what is leaking?
EDIT: No leaks was found. It was just extra grease dealer put on axle
Old 10-05-19, 11:27 AM
  #65
tecman
tecman's Avatar
Looks like splatter from the drive shaft?
Old 10-05-19, 06:41 PM
  #66
nebrou
nebrou's Avatar
Anyone had a leak like this?
Old 10-05-19, 06:47 PM
  #67
Acrad
Super Moderator
Acrad's Avatar
Received 3,638 Likes on 2,383 Posts
I've seen some grease splatter on mine like tecman states from prop shaft grease but not quite that much. Probably want to clean up with some brake cleaner and keep an eye on it.
If it quickly reappears might be a rear main seal as in area between engine and AT
Old 11-07-19, 10:25 AM
  #68
ObsidianBl
ObsidianBl's Avatar
Went to move the grease gun to get something and noticed it leaked a bunch of the oil from the bottom that was in the grease. I might have to invest in the tub of grease instead of the tube next time. I threw away the caps and left the tube inside the grease gun.
Amazon Amazon
Old 12-14-19, 06:39 AM
  #69
william489
william489's Avatar
Originally Posted by Acrad
I wish I had a lift as well.
I think there are other options out there as well but this item on your existing grease gun makes things a lot easier.
https://advancedenginetech.com/product/safelock/
I plan to do this next few days, a quick question, do I have to jack up the gx off ground, some youtube videos mention that, but it looks like none of folks here do that, I hope I have the luck to get the zerks lined up properly for me. I have home made 2x10 ramps, so that gives me about extra 4.5'' clearance.
Old 12-14-19, 06:42 AM
  #70
Acrad
Super Moderator
Acrad's Avatar
No... you don't have to jack up. Just personal preference of extra room for me. I've done it on the ground as well.
william489 (12-14-19)
Old 12-14-19, 07:37 AM
  #71
downshift1
downshift1's Avatar
Do use caution when greasing the slip yokes as you can over grease them and cause a hydro-lock situation where the shaft can't compress due to the grease filling the cavity.
Old 12-14-19, 08:23 AM
  #72
william489
william489's Avatar
So this means I need to drive/adjust the gx back and forth a bit on ramp, so I can reach all 6 zerk fittings. First time doing this.
Old 12-14-19, 08:25 AM
  #73
Acrad
Super Moderator
Acrad's Avatar
More than likely. I have always found 1 or two that were harder to get at and had to move vehicle a little.
Old 12-14-19, 08:28 AM
  #74
william489
william489's Avatar
Got it. Thanks. Total 2 slip yokes? I will do 5 to 6 pumps each fitting to be conservative. That is what I read here, never exceeding 10 or 12 pumps
I asked lexus to lube it last time in service, but I am not sure if they ever do all 6 fittings.
Old 12-14-19, 08:41 AM
  #75
william489
william489's Avatar
Got it. Also I probably have to take skid plate off (the one for front diff oil chg) to reach out of the fittings?
