shift paterns
Anyone know if the computer controlled auto trans on the GX "learns" your driving style, and thus shift according to what is "normal" for you? We have about 1100 miles on our so far. Mostly the wife's grocery getter around town. But we have taken it to our mountain cabin twice. 20.1 mpg since new, not too bad for a car of that weight. But anyway, I am unhappy with the trans shifting. It shifts ok, but what I really don't like is when in sport mode, you are not in complete control. So for example, when I want 4th gear, I WANT 4th gear. I don't want it to decide that 3rd is more appropriate. I told it I want 4th gear, and nothing else will do! But it takes over and decides on another gear. Isn't that the intension? That the driver can decide when to shift, and what gear they want to operate in. Isn't that what sport mode is all about? WTF!!!!!!!!!
I had an 8th Gen Legnum VR4 (Galant Wagon) with the INVECS II transmission that learns your driving style and adapts the transmission ECU to suit. It would still have a safe working limit it believed you needed to up/down**** at when in Tiptronic mode to keep the engine and transmission safe.
My GS460 has a bit of a mind of its own when driving through twisty mountain roads. I believe it is just the car maintaining some autonomy in manual shift mode to prevent anything it deems dangerous to the car.
Super Moderator
I think most in last 10 years have some adaptive functionality. Undoubtedly other models had some to a degree before but fewer models.
I do agree this is the least controllable AT in Sport/Manual mode but probably few actually change it up much in this rig. I use mine all the time though and manually shift to give little extra engine braking in traffic or when towing.
When mountain driving, I prefer to control what gear its in. both for breaking and accelerating out of a turn. So it downshifts when it doesn't need to. Mostly when coming out of a turn. But just something I need to get used to. I need to adapt my driving to this vehicle, more than any I have ever owned. Most I could just get in and drive effectively. This one has taken more getting used to. Just too much computer junk interfering with good driving style. Computers trying to make up for the average poor driver.
The gearing is kinda off sometimes especially coming out of a turn and merging into freeway, you kind have to step into it. But it is smoooooth.
I just found out today that if you in S mode and in a lower gear, hold the shifter UP for a second or so will automatically go to the highest gear, which is 6. It doesn't work for downshift which is understandable to prevent accidental shifting to 1 from higher speed and damage something.
Super Moderator
For the brave to try... :-)
https://www.vividracing.com/catalog/...150794664.html
The all-new 2016 VR Tuned Tool is a fully reworked and reprogrammed new plug n play OBD tool that not only unlocks manufacturer's transmission settings within the vehicles control modules to give better gear shifts, increased performance and release torque. It now also provides adaptation reset as standard helping you get the most from your vehicle, which provides an essential component in your vehicles modifications and upgrade path.
The new updated 2016 VR Tuned Tool was developed with three advanced functional requirements:
This includes changing the transmission shift speed pointer to a faster/different setting. The internal components that make up the mechanics of the transmission have a wide range of tolerance and multiple settings allowing manufacturers in most cases to use single components across a whole range of vehicles, from a VW golf to a Lamborghini Aventador. They all contain similar if not the same generation components, usually built in the same factory, but have model specific programs that are used for their specific application.
The New 2016 VR Tuned provides a Clean Start Point
Over time your vehicle may of adapted to a slower shift due to a previous owner or the way the vehicle has been driven over time. Unique to the new 2016 VR Tuned Tool we have now added the extra function of resetting this to provide a 'Clean slate' install. This is an essential step when modifying or tuning as it gives the user a factory clean reference point and base line. This is the first time we have added this feature to our new line of VR Tuned products and only available on the new 2016!
What's all the Tourque About?Torque Limits are also set in various systems and control modules within the vehicle; this is set by the manufacturer and is one of the easy ways to electronically limit power in certain models of vehicles. This allows the manufacturer to release many different power variants with different driving characteristics with only a single engine. This is a much more cost effective way of creating a vehicle range without the need to manufacture multiple engines at different power levels. We all know how many power variants are available for the VW Golf 2.0TDi. Same engine different software settings.
The NEW 2016 VR Tuned Releases Lost PowerBy simply unlocking, resetting and amending the torque settings to the various other manufacturers settings we can allow the vehicle to produce and deliver power safely and still stay within the manufacturers specified limits.
This style of 'derestricting' ensures that key settings such as clamping force, slip, torque limits, shift speeds etc. all remain within not only manufacturers spec, but also component spec, thus never exceeding safety of shortening component life.
VR Tuned Gearbox Tuning Lexus GX460 GX470
- 1. The need to improve and optimize the gear shift speeds and modify torque settings in the modern automatic gearing systems to improve the overall driving experience.
- 2.The need to create a simple to use Plug n Play OBD solution which is easy to install and at an affordable price.
- 3. Provide the end user with a tool that allows the vehicles adaptation settings to be reset to factory, simply and efficiently.
Super Moderator
Yeah... I do it as well in all of my other manu-matic cars. My Wrangler has a manual so required to row the gears in that one.
Read "Pulling the shifter to the left", got confused by what you meant. Realised your car is opposite to mine in Australia.
outlaws
07-03-09 07:33 AM
koreanpers
12-30-03 08:54 AM
