How do I turn on my Bluetooth in my GX460 Lexus.
I would have to read the manual again, can't remember off the top of my head. Did you try that........reading the manual, there are lots of other interesting things in there too.
GX460 with Nav? Tap Menu hard key then Bluetooth soft key on screen. Tap Add and
get your phone into Bluetooth. The GX and the phone will do the rest. If yours is a
2010-2012 you will need to transfer contacts from the phone menu, "Contacts" and also
pair that device separately for Audio, Menu/Audio/Add Note: the GX will pair up to four (4)
phones and up to two (2) Audio Devices, your phone will be one of each. If yours is a
2013-2017 then it will pair and update everything with the first pairing. On these younger
trucks you can press and hold "off hook" to access Siri on an iPhone 4S or newer.
Acrad (06-02-17)
Super Moderator
eugenez
NX - 1st Gen (2015-2021)
05-27-16 09:11 PM
