Wonder if the sticker in mine was added when then previous owner had the factory hitch installed? This sticker is around the other tags on drivers door.
The stickers are applied when a "Port Installed Option" is installed. The factory GVWR placard
was accurate as built but adding anything reduces the payload. OP's 6 lbs. adjustment might have
been a couple of headrest mounted Rear Entertainment TV's. A full set of All Weather Mats come
in at 15 lbs. The trailer hitch receiver lists out as 47 lbs and of course includes an 11 lbs. bar and ball.
The 88 lbs. sticker would seem to be a cumulative figure because no one item commonly installed
weighs that much.
