View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
0%
2011 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar1-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar1.gif)
![](https://www.clublexus.com/forums/images/polls/bar1-r.gif)
0%
2011 - Premium (stock Crawl) - Added MTS
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
0%
2012 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar6-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar6.gif)
![](https://www.clublexus.com/forums/images/polls/bar6-r.gif)
0%
2012 - Premium (stock Crawl) - Added MTS
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#166
I haven't driven with it on like this but looks like MTS "MUD & SAND" or snow for that matter can be run in 4H. I haven't tried turning on at speed but seems to be the only mode that doesn't require 4L and can apparently be used above 7 MPH unlike the other modes according to what I have seen in 4Runner forums.
#167
Super Moderator
I'm only going off what I saw on the Prado forums but they reported that MTS would show up if Drive Support Computer was updated but wouldn't work because the crawl profile wasn't active in the skid control ECU. Of course you need the console switch to activate crawl.
For the real adventurous some of the RU Prado users were doing some manual switches to activate it. If this works you are talking a really cheap mod.
#168
Super Moderator
A few thoughts about MTS from 4Runner forum
"My understanding was that it just changes the sensitivity of the throttle and the traction control system."
"It also changes brake response. Normally there is a good amount of travel in the brake pedal when using MTS the travel is greatly decreased, which is really nice offroad"
"In MTS, it will allow more wheel spin before cutting throttle and applying brakes. Similarly, the ABS doesn't kick in and release the brakes when a wheel stops and digs in."
#169
#170
Super Moderator
If you look at schematic LG is being severed 13,14,15 are being allowed for use
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/1010x636/80_crawl_switch_diagram_ac447a11bc7b836e2b6980aa2a0bbdc0870ec14c_f920f6884b545fc06dec84f667eb382d8ce5860a.jpg)
#171
#173
Oh well megazip canceled the order so I ended up ordered it from a US dealer in Miami. Hope it's in stock LOL.
#174
I ordered from magazip yesterday and just found one from a wrecking yard. When did you order from them? They havent cancel mine yet but if yours is earlier than mine, then I guess I have to look into getting the other one.
#175
I was neck deep trying to find a salvaged one online yesterday without any luck.
#176
I also asked Motor Heads Japan website and accord to them that part is for oversea only. It doesn’t make sense. Another member checked on Canadian website and couldn’t find any listing for it which could means and different part number may be used in canada and else where.
#177
I ordered it 2 days ago and they sent the cancel email yesterday.
#178
Try looking for some different part numbers and look at the picture they posted. Sometimes they post wrong parts number. The one I bought was post as 60100. Just remember to confirm with the seller before placing the order.
LexOverlnd (02-27-18)
#179
thanks for the tip. I guess I’m also at a loss as to where I should be looking.
#180
