View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2011 - Base - Added Crawl
0%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Premium (stock Crawl) - Added MTS
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#286
https://www.discountpartsmonster.com...QtNmwtdjgtZ2Fz\
Not sure if there is anything in stock but it's the cheapest I found.
#287
#288
I think most of the sites are using the same or similar central distributors. They are going with what the distro has on the catalog. Only after the order was put in that the dealer contact them and found out part is no longer available. I think this is the case with some of the dealers in the south/east.
#289
Super Moderator
I might be off a year or so but looks like crawl control was 3 speeds for '08-'14 LC and '08-'13 LX 570 and then upgraded to the 5 speeds that the GX is capable of.
EDIT: I've seen some posts that '13 LC went to 5 speed instead of '14
bbqsoup (03-01-18)
#290
@bbqsoup, I'm having second thoughts and concerns because mine is a Base model, not a Prem like Acrad. I'm wondering if mine will have the same wiring as his and therefore this mod may not be applicable to my GX. I'm betting they have two different wiring harnesses - 1 for the base & 1 for Lux/Prem.
If I start going thru this process only to find that I am right, I'll contact you if you have no luck procuring one. All of this of course is predicated on my acquisition of the console Combi-switch.
@Cicio - I checked with the monster, I was trying to get it at a cheaper price, so you may have luck obtaining one through them.
"Hello, no unfortunatly our prices are already at the lowest possible and we can't go any lower than what we have them listed for.Thank you."
They did not say that it was out-of-stock.
#291
Super Moderator
EDIT: Would any '10-'13 Base or '14+ Base/Premium owners be up to looking at their wiring to confirm their wiring status on switch and driver support?
I can't guarantee anything of course but odds are high if on your driver support computer you have the Black / Green / Blue wires in upper left area. The wires goto the console switch.
These are the CC wires used in the schematic. This picture was taken removing soft trim above the glove box & below wood trim... glove box wasn't removed for picture. I removed the padding piece next to passengers left leg but you might be able to do it without removal as well.
EDIT: IIRC... on the Prado's that didn't have these wires they were still able to run wires and get it to work. Of course that takes the project in a different direction from relatively plug and play.
Or if you lift your console switch like in tecman's video
Do you see the blue and black wires? This is the console switch connector on the underside
[Wires on console switch for suspension related settings]
[Crawl/DAC/4WD-repost]
GB2011GX (03-02-18)
#292
The following 2 users liked this post by hzhao:
GB2011GX (03-02-18),
LexOverlnd (03-02-18)
#293
Some bad news. I got the confirmation from Lexus of Kendall that 60080 is not the same as 60070. He said it doesn’t have have the SPEED and ON/OFF button.
It is a global part shortage. Lol.
Acrad (03-02-18)
#294
My Base GX does has 3rd row power folding seats (as opposed to manual?), so maybe it is doable.
#295
Super Moderator
I was hoping I could see the connector in these '12 wiring harnesses... talk about looking for a needle in a haystack
#297
Super Moderator
A couple days back I made an inquiry with Megazip again about ordering another one as a ticket against my previous order. I got the initial response about talking to vendor and a response in 1-2 days. Still awaiting to hear back from them.
bbqsoup (03-02-18)
GB2011GX (03-02-18)
#299
Super Moderator
Did salvage yard send you a tracking number for the switch?
#300
Super Moderator
So much simpler and cheaper on the Prado for this switch
Might be a retrofit option if someone wanted to mount some other place and run some wires.
or find some bracket to mount lower on the dash like a brake controller ....lots of different aesthetic and functional scenarios
It is ---> 84970-60060
https://carmarka.com/en/toyota-switc...wl-84970-60060
https://www.megazip.net/zapchasti-dl...-relay-7456345
