View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2011 - Base - Added Crawl
0%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Premium (stock Crawl) - Added MTS
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#331
Super Moderator
Quite a number of 031 on eBay showing compatibility on pretty much all model years.. I don't expect too many wrecked '18s at this point. This is a good sign. Still looks like 040 for '14+ is the one you want. Of course the first installer of this module will need to confirm for all of us.
#332
Super Moderator
040 still isn't confirmed for MTS on '14+ but here is some pricing .
PN: 859A1-60040
Discount Parts Monster - $186.73
OEMVehicleParts - $190.77
Megazip - Out of Stock / no Price Listed
LexusPartsNow - $202.96
Lexus of Kendall - $194.84
PlazaMotorsHQ - $198.09
MyLParts - $218.76
Longo Lexus - $198.09
LParts247 - $216.06
Wholesale Distributor - SGNAuto
PN: 859A1-60040
MyLParts - $218.76
LParts247 - $216.06
#333
Super Moderator
Foreign market only so they don't sell this one.
EDIT: I sent an inquiry off to Motor Heads Japan about availability of the Prado switch. For those that are interested in that path they may have a better price and their shipping costs are low. I'm not sure if this is correct or not but I thought I read in one of the RU threads that MTS and Crawl aren't available on the Prado in Japan so it might be one of those parts that isn't available from this vendor.
#334
Super Moderator
oemvehicleparts.com says they have three more 070's inbound the second week of April
bbqsoup (03-04-18)
#336
#337
That makes sense. The 010, 020, 031, 040, etc. are "Drive Support Switch ECU" which connects to Drive Support ECU. For US spec GX, the Driver support package does not have MTS, therefore, the Drive Support Switch EUC should be the same, '10 to '13 uses 010 and '14+ uses 031. If Canadian members here with Technology or Executive Package on '14+ maybe able to verify if their Drive Support Switch ECU is 040, since those packages include MTS.
#338
Super Moderator
That would definitely seal it on the 040 if a Canadian member with one of the above packages could chime in.
#340
Super Moderator
Something to think about if you aren't comfortable doing the zero point calibration or steps aren't working for you. I can't imagine it being more than an hour of labor but you could request them to do a zero point calibration. A Toyota dealer or independent would likely be a lot cheaper. I've seen some state on 4Runner forums they do this after lifts and other off-road mods if they perceive stability control is kicking in too much. If they ask you why... you could always say "Piece of mind" :-)
Word of warning... I believe if the calibration is erased and you are not successful with reset it would leave the vehicle's stability control and ABS in a deactivated limp mode. I'm not positive but I believe that to be the case. If unsuccessful you need to erase and try the calibration again.
#341
Acrad, can you post the steps for zero calibration using TechStream? Do you happen to have any screenshots too? Thanks.
#342
Super Moderator
Here are the text instructions. I added to my signature.
https://www.clublexus.com/forums/gx-...l#post10104291
The screens you will see with TS will look like this. These aren't mine.
Connect TS to the vehicle. Enter into the ABS/VSC/TRAC computer:
https://www.clublexus.com/forums/gx-...l#post10095237
bbqsoup (03-06-18)
#343
Super Moderator
From Megazip: “Unfortunately, part 84970-60070 is no more available and can not be supplied. We apologize for inconvenience! We deleted it from our catalogue”
#344
I got the message from the supplier I ordered 2 from that they are on back order with Lexus and there are NONE in the US.
I cancelled my order.
#345
Super Moderator
oemvehicleparts.com confirmed for me that 040 is what is being used in '14+ Canadian trims with Technology or Executive packages.
They seem to be very knowledgeable and responsive.
hzhao (03-06-18)
