View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2010 - Base - Added Crawl/MTS
0.80%
2010 - Premium - Added Crawl
0.80%
2010 - Premium - Added Crawl/MTS
1.60%
2010 - Premium (stock Crawl) - Added MTS
3.20%
2011 - Base - Added Crawl
0%
2011 - Base - Added Crawl/MTS
4.00%
2011 - Premium - Added Crawl
1.60%
2011 - Premium - Added Crawl/MTS
2.40%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Base - Added Crawl/MTS
2.40%
2012 - Premium - Added Crawl
0.80%
2012 - Premium - Added Crawl/MTS
4.80%
2012 - Premium (stock Crawl) - Added MTS
0%
2013 - Base - Added Crawl
0.80%
2013 - Base - Added Crawl/MTS
4.80%
2013 - Premium - Added Crawl
0.80%
2013 - Premium - Added Crawl/MTS
5.60%
2013 - Premium (stock Crawl) - Added MTS
1.60%
2014 Base - Added Crawl
0%
2014 Base - Added Crawl/MTS
3.20%
2014 Premium - Added Crawl
0.80%
2014 Premium - Added Crawl/MTS
4.00%
2014 Luxury - Added Crawl
0.80%
2014 Luxury - Added Crawl/MTS
3.20%
2014 Luxury (stock Crawl)- Added MTS
4.80%
2015 Base - Added Crawl
0%
2015 Base - Added Crawl/MTS
2.40%
2015 Premium - Added Crawl
0%
2015 Premium - Added Crawl/MTS
1.60%
2015 Luxury - Added Crawl
0.80%
2015 Luxury - Added Crawl/MTS
0.80%
2015 Luxury (stock Crawl)- Added MTS
0.80%
2016 Base - Added Crawl
0%
2016 Base - Added Crawl/MTS
4.00%
2016 Premium - Added Crawl
0%
2016 Premium - Added Crawl/MTS
4.00%
2016 Luxury - Added Crawl
1.60%
2016 Luxury - Added Crawl/MTS
0.80%
2016 Luxury (stock Crawl)- Added MTS
0.80%
2017 Base - Added Crawl
0%
2017 Base - Added Crawl/MTS
3.20%
2017 Premium - Added Crawl
0%
2017 Premium - Added Crawl/MTS
2.40%
2017 Luxury - Added Crawl
0.80%
2017 Luxury - Added Crawl/MTS
0%
2017 Luxury (stock Crawl)- Added MTS
7.20%
2018 Base - Added Crawl
0%
2018 Base - Added Crawl/MTS
0.80%
2018 Premium - Added Crawl
0.80%
2018 Premium - Added Crawl/MTS
4.00%
2018 Luxury - Added Crawl
0%
2018 Luxury - Added Crawl/MTS
0.80%
2018 Luxury (stock Crawl)- Added MTS
0.80%
2019 Base - Added Crawl
0%
2019 Base - Added Crawl/MTS
0.80%
2019 Premium - Added Crawl
0%
2019 Premium - Added Crawl/MTS
5.60%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
2019 Luxury (stock Crawl)- Added MTS
2.40%
Voters: 125. You may not vote on this poll
MOD: #Crawl #Control (CC) and #Multi #Terrain #Select (#MTS)
Old 03-14-18 | 06:38 PM
  #376
kidkb's Avatar
kidkb
Originally Posted by LexOverlnd
Last I heard it was getting in 4/10/18.
where did you order yours from Lex? My driver support computer arrived today but still no luck on the 70. It was confirmed 80 doesn’t work, is that right? Also, no MTS without the new switches right?
Old 03-14-18 | 06:49 PM
  #377
Acrad's Avatar
Acrad
Super Moderator
Yeah... 080 won't work...it's the model that looks like this. Everything I read on Prado forums indicated that MTS won't go live until Crawl is active. You can change settings but they won't work. That being said if you plug 020/040 in now you will see MTS menu options. Probably no harm in installing it before you get your 070 switch though.
Old 03-14-18 | 07:20 PM
  #378
kidkb's Avatar
kidkb
Thanks for the info and confirmation on that!
Old 03-14-18 | 07:28 PM
  #379
LexOverlnd's Avatar
LexOverlnd
I ordered it from oemvehicleparts.com.
Old 03-14-18 | 07:37 PM
  #380
Acrad's Avatar
Acrad
Super Moderator
Interested next winter... since melt is solidly on for me now.. on what MTS Sand/Mud mode offers in the snow off and on road. This mode can be run in 4H. You have to engage below 7 MPH IIRC. Gonna play with crawl and MTS some more this weekend around my cabin.
Found this graphic on toyota-4runner.org for MTS use cases
Old 03-15-18 | 04:39 PM
  #381
Acrad's Avatar
Acrad
Super Moderator
I am really curious if the Prado threads weren't entirely accurate and that MTS might work without the crawl switch. I find noticeably less accelerator sensitivity with MTS set on Mud & Sand in 4H.
If anyone has the module but doesn't have 070 yet it might be a good test to confirm whether MTS could be a standalone option in itself.
Old 03-15-18 | 06:23 PM
  #382
bbqsoup's Avatar
bbqsoup
I just received 020 too so I may just do that. Is it right under the glove box and access it by remove the panel and the glove box?
Old 03-15-18 | 06:33 PM
  #383
Acrad's Avatar
Acrad
Super Moderator
Yeah. It's on the left side of the glove box.
https://www.clublexus.com/forums/gx-...l#post10096164
https://www.clublexus.com/forums/gx-...l#post10123166
bbqsoup (03-15-18)
Old 03-15-18 | 08:33 PM
  #384
LexOverlnd's Avatar
LexOverlnd
I might do the same
Old 03-16-18 | 06:21 AM
  #385
tuandino's Avatar
tuandino
I'm quietly following this thread. Kudos to acrad and others for all your tinkering works. I'm kinda debating whether or not i should do this mod. I don't really go off-road so the need for crawl control and MTS is kinda low.
Old 03-16-18 | 07:27 AM
  #386
Acrad's Avatar
Acrad
Super Moderator
Just my opinion...
Personally if I didn't dabble with some off-roading I wouldn't likely install these mods. It's up in the air whether long term the cost of the parts would give one any return on resale.
It might be a compelling feature for some on what model they buy on the new or used market. I've heard more than one say "I'd like to have crawl but I didn't want to spend the money on a Luxury" or buy that model since it has the suspension upgrades and they were going to remove those pieces anyway.
The following 2 users liked this post by Acrad:
GB2011GX (03-20-18), tuandino (03-16-18)
Old 03-16-18 | 09:37 AM
  #387
tuandino's Avatar
tuandino
Just my opinion...
Acrad, your work on this mod has inspired me to join the fun! lol
I have 2018 GX Luxury w/o driver assist package. Correct me if i'm wrong, so the consensus on if i want crawl control and MTS, then these 2 parts are what I need, correct? xxx70 is still hard to find?
switch assembly : 87970-60070
ECU: 859A1-60040
I don't think anyone with 18' GX here has done mod yet, I don't mind being the first and shared my experience.
Old 03-16-18 | 09:51 AM
  #388
Acrad's Avatar
Acrad
Super Moderator
EDIT: I plan to start updating the first post of this thread with quick links to relevant pieces of this project so everyone doesn't have to wade through the closely approaching 30 pages. I realize the poll now takes up a large chunk at the top. I didn't realize that was going to carry over to every page.
Correct on part numbers and availability. We may know within the next 1-2 weeks on a firm 040 install that shows MTS live on a '14+
It sounds like a few are going to try out just putting in the MTS module to see if that can be a standalone option.
Your current console switch on your Luxury will go from this
to this
ECU: 859A1-60040
Old 03-16-18 | 12:19 PM
  #389
tuandino's Avatar
tuandino
any new lead on who we can order xxx70 from?
Old 03-16-18 | 12:55 PM
  #390
Acrad's Avatar
Acrad
Super Moderator
They seem to be on quite a backorder.
I think best bet at this point is to get on the waiting lists at DiscountPartsMonster or oemvehicleparts (these two seem to be the cheapest). Since Carmarka still has part online I've initiated a purchase for one this morning. I'll let you know if they come back with it being on backorder. If purchase goes through I'll sell it to another member here (assuming forum rules allow this) on a number lottery. I think back in January with shipping the Carmarka price was around $250/shipped but I think others that tried ordering said there was a 45 day backlog.
