View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
0%
2011 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar1-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar1.gif)
![](https://www.clublexus.com/forums/images/polls/bar1-r.gif)
0%
2011 - Premium (stock Crawl) - Added MTS
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
0%
2012 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar6-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar6.gif)
![](https://www.clublexus.com/forums/images/polls/bar6-r.gif)
0%
2012 - Premium (stock Crawl) - Added MTS
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#392
Super Moderator
If you do just take your time, take pictures too even if you don't think you will need them. Having some trim and molding tools helps keep you from scratching things too. Also watch your hands in dash area behind glove box. It seems like on every car I have ever worked on the metal back there are like knives
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/404x344/screen_shot_2018_03_16_at_4_25_45_pm_dd0716fca64bcaa7b36ce476c8a20f33e56fd1cd.png)
#394
Super Moderator
That is awesome. A confirmed 040. Congrats :-)
#396
Installed module 020 and MTS showed up.
Went testing and stuck in the mud and ripped the passenger side rear mudflap![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/3793f82b_d372_4388_812a_d2f81f4813e2_c05c8dbc574ac37d5f884edd45644e770ac86771.jpeg)
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/5bd901c3_f4a7_47e9_96c2_4a8497877110_ed1bfc08840240aba35c738863d1a1cf0fcfc25b.jpeg)
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/dacc1d6c_941d_4398_9a0c_178a2cdfcfa9_e00b5c48a22dccf6f4c93a3fe7dfb768e30836d4.jpeg)
#398
Super Moderator
bbqsoup: ouch on the mudflap... are you going to need to buy a new one or does it just need to be reseated?
It may be that crawl profile does need to be live for it to work.
#400
Super Moderator
Mine seems like throttle has less sensitivity in the short test I did today
Does the MTS icon with vehicle driving flat show up on dashboard when MTS is on?
https://www.clublexus.com/forums/gx-...l#post10123029
#402
Yes the green icon showed up on the dash.
I’ll check it out again tomorrow.
Unrelated, after I got out of the mud and power washed it, the steering wheel vibrates at freeway speed,
do you think it’s from mud caking the inside and throwing of balance? The AT3W arrived too so
I’m changing out in a week.
#403
Super Moderator
I wonder if a balance weight got kicked off one of the front tires?
Did you get backside of tires cleaned really well?
#404
Super Moderator
If you can wait on order Carmarka claims they can still get part. I assume this would be common price to US.
https://carmarka.com/en/search/index?q=84970-60070
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/845x390/screen_shot_2018_03_17_at_5_42_25_am_bf88e4a658b5b84e353cd4d59e5a87ec0e7d3cae.png)
#405
Super Moderator
I took mine down onto the sand beach of a nearby lake and tested it out some more in MTS/4H/Mud&Sand. There is definitely a different throttle mapping. It's not quite like 2nd gear start mode but in that direction since it is first gear.
