View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
0%
2011 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar1-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar1.gif)
![](https://www.clublexus.com/forums/images/polls/bar1-r.gif)
0%
2011 - Premium (stock Crawl) - Added MTS
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
0%
2012 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar6-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar6.gif)
![](https://www.clublexus.com/forums/images/polls/bar6-r.gif)
0%
2012 - Premium (stock Crawl) - Added MTS
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#406
Super Moderator
From I gather of other posts online about MTS---->
• MTS is an adjustment of ATRAC
• On one end of the scale "Mud and Sand" allows the maximum wheel slip ratio before braking
• On the other end "Rock" allows the minimum wheel slip ratio before braking
I wonder if "Rock" is even more aggressive than standard ATRAC on models without MTS?
Strong chance MTS can be a standalone option. One of the requirements of using MTS is that CRAWL is not enabled.
#407
#408
#409
I can confirm MTS works without the crawl control switch. I installed the Driver Support ECU version 020 yesterday and took it to an area near my home that has a small area with mud/sand from a river. I activated MTS and immediately noticed a difference in throttle/braking. I haven't played with the other options (Mogul, Rock, etc) that require 4LO just yet.
I am super excited to try this out at the OHV park near my house- Lots of sand and deep mud to play in.
The following 4 users liked this post by kidkb:
#410
#411
Super Moderator
In reality, MTS and Crawl are very similar in terms of function with one major difference, that is Crawl is a fully automatic driving mode and you just control the steering. With MTS, you will still have to "drive" the car. So, the ATRAC should have the functions already, both Crawl Switch and Drive Support Switch ECU are only made user accessible to those function, IMHO.
Acrad (03-19-18)
#413
The following 2 users liked this post by BA777:
Acrad (03-19-18),
LexOverlnd (03-19-18)
#414
2014-17 owners that added the -40 module for MTS.... Did you also “unlock” the dynamic lines on the rear view camera when in reverse?
#415
I already have the dynamic guidelines for the rear camera before adding the 40 module. So it did not make a difference. Upgrading to the 40 module also did not add the Trajectory line to the front camera for me. Can someone else please confirm also?
#416
bbqsoup (03-23-18)
#418
I placed order for the xxx70 switch with carmarka and xxx40 module with discountpartsmonster. Carmarka said that it would be 45 days wait just like Acrad mentioned. Hopefully the xxx40 module will come much before than so i can play around with it. How many of you have successfully received your xxx70 switch?
#419
For '14 GX, the reverse camera view with dynamic guide line (the yellow part of line that turns with steering wheel) only comes with Driver Support Package, if US spec GX all uses 031 regardless with or without Driver Support Package, then where is the dynamic guide line come from? It has to be associated with Park Assist ECU, but that one does not have different versions for various options......
#420
Also interesting to see on others when they installed the 20 module in the menu it lists “Cam Position”. I don’t have that option listed in mine.
