This is incredible. Thanks Acrad35751 and others for pioneering this. To me, these are the most satisfying modifications to a car, OEM parts unlocking highly useful functionalities for relatively cheap. This should be sticky'd at the top of the forum.
Now to find an 070 for "relatively cheap"
Unfortunately this is CarMarka’s current status
They sent me the same notice like that when i placed my order. I ordered my 070 unit from them on 3/19 ... got it at my door on 4/16. Roughly 4 weeks including shipping time
Well, I got motivated and got everything installed. MTS shows up as expected, but for the life of me I can't get the ABS Reset/Test to stick (VSC stays illuminated with a C120A code) so CC shows up. I've done the reset and test about 15 times to no avail. I'm running TS 8.xx.xxx, so I'm going to upgrade to 12.xx.xxx and see if I have any better luck.
If TS route didn't work for you, you may want to try the short pin method. It's not too difficult as long as you keep the timing correct.
On reset part, the last step I believe it says "... wait for 3 seconds then turn ignition off....", When I tried third time, I waited probably 15 seconds before I turned ignition off. I can't say it has anything to do with that, but certain won't hurt to wait a little longer before turn the ignition off to complete the reset part. Many of us need multiple times of reset to make it successful, I suspect its a timing issue with the cables we all have, how it communicated between software and vehicle, so take it slow and be patient.
