View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2011 - Base - Added Crawl
0%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Premium (stock Crawl) - Added MTS
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 125. You may not vote on this poll
MOD: #Crawl #Control (CC) and #Multi #Terrain #Select (#MTS)
coinball (04-22-18)
#542
On reset part, the last step I believe it says "... wait for 3 seconds then turn ignition off....", When I tried third time, I waited probably 15 seconds before I turned ignition off. I can't say it has anything to do with that, but certain won't hurt to wait a little longer before turn the ignition off to complete the reset part. Many of us need multiple times of reset to make it successful, I suspect its a timing issue with the cables we all have, how it communicated between software and vehicle, so take it slow and be patient.
#543
coinball: Just to confirm... car is parked on flat spot with wheels straight ahead? You may need to explore the wire method hzhao suggested too.
EDIT: This post on using the wire method on 4Runner forum might help.
Not likely cause but I think one of the USB ports on my laptop is a little flakey.. might even be a physical connector issue. Anyway... I notice when I use TS on this port I have a higher incidence of a potential TS communication error than other ports. Maybe try that out as well.
coinball (04-22-18)
#544
If I have to get medieval and do the wire reset, so be it.
EDIT - this is the perfect situation for this Rambo 3 flashback:
#546
#547
You'll be fine. It is nice there is a backup option if all else fails with TS. A new reference video of steps performed would be good though. All other zero point videos are for the 4Rs and the FJs. I wish I had done one originally.
#549
Every time I was doing a mod, always thought about to do a video. But with no one at side to do it for you, it is just become unpractical to do. There is always a level of concentration that you have to maintain without mess up something. In fact, I often couldn't remember to take the picture before I get everything put back. I guess I will keep my current job and forget about the idea of being a producer
#551
I got the solid VSC light when I did mine too. Can’t remember exactly what I else I did beside wait longer before turn off the truck after exit. In the video, I didn’t see you turn the truck off. You can also try to turn off before click exit.
Also try pressing the cc on/off see if it helps too.
You can try version 12.xx see if it helps. I used version 12.00.127
coinball (04-22-18)
#552
Acrad (04-22-18)
#554
#555
