View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2010 - Base - Added Crawl/MTS
0.81%
2010 - Premium - Added Crawl
0.81%
2010 - Premium - Added Crawl/MTS
1.63%
2010 - Premium (stock Crawl) - Added MTS
3.25%
2011 - Base - Added Crawl
0%
2011 - Base - Added Crawl/MTS
4.07%
2011 - Premium - Added Crawl
1.63%
2011 - Premium - Added Crawl/MTS
2.44%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Base - Added Crawl/MTS
2.44%
2012 - Premium - Added Crawl
0.81%
2012 - Premium - Added Crawl/MTS
4.88%
2012 - Premium (stock Crawl) - Added MTS
0%
2013 - Base - Added Crawl
0.81%
2013 - Base - Added Crawl/MTS
4.07%
2013 - Premium - Added Crawl
0.81%
2013 - Premium - Added Crawl/MTS
5.69%
2013 - Premium (stock Crawl) - Added MTS
1.63%
2014 Base - Added Crawl
0%
2014 Base - Added Crawl/MTS
3.25%
2014 Premium - Added Crawl
0.81%
2014 Premium - Added Crawl/MTS
4.07%
2014 Luxury - Added Crawl
0.81%
2014 Luxury - Added Crawl/MTS
3.25%
2014 Luxury (stock Crawl)- Added MTS
4.88%
2015 Base - Added Crawl
0%
2015 Base - Added Crawl/MTS
2.44%
2015 Premium - Added Crawl
0%
2015 Premium - Added Crawl/MTS
1.63%
2015 Luxury - Added Crawl
0.81%
2015 Luxury - Added Crawl/MTS
0.81%
2015 Luxury (stock Crawl)- Added MTS
0.81%
2016 Base - Added Crawl
0%
2016 Base - Added Crawl/MTS
4.07%
2016 Premium - Added Crawl
0%
2016 Premium - Added Crawl/MTS
4.07%
2016 Luxury - Added Crawl
1.63%
2016 Luxury - Added Crawl/MTS
0.81%
2016 Luxury (stock Crawl)- Added MTS
0.81%
2017 Base - Added Crawl
0%
2017 Base - Added Crawl/MTS
3.25%
2017 Premium - Added Crawl
0%
2017 Premium - Added Crawl/MTS
2.44%
2017 Luxury - Added Crawl
0.81%
2017 Luxury - Added Crawl/MTS
0%
2017 Luxury (stock Crawl)- Added MTS
7.32%
2018 Base - Added Crawl
0%
2018 Base - Added Crawl/MTS
0.81%
2018 Premium - Added Crawl
0.81%
2018 Premium - Added Crawl/MTS
4.07%
2018 Luxury - Added Crawl
0%
2018 Luxury - Added Crawl/MTS
0.81%
2018 Luxury (stock Crawl)- Added MTS
0.81%
2019 Base - Added Crawl
0%
2019 Base - Added Crawl/MTS
0.81%
2019 Premium - Added Crawl
0%
2019 Premium - Added Crawl/MTS
4.88%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
2019 Luxury (stock Crawl)- Added MTS
2.44%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
Old 02-05-18, 02:42 PM
  #46
Acrad
Super Moderator
Acrad's Avatar
Received 3,618 Likes on 2,369 Posts
Here is calibration guide. You can either do this with Techstream or a wire plugged into a couple connectors on the OBD port.
File Type: pdf
hzhao (02-05-18)
Old 02-05-18, 05:01 PM
  #47
hzhao
hzhao's Avatar
Now I understand from Russian video the guy is keep putting the SST in and out while couldn't understand what he was talking about all because it needs to be do it 4 times within 8 seconds to clear the memory
Old 02-05-18, 05:03 PM
  #48
hzhao
hzhao's Avatar
Now with all the important information provided by Acrad35751, I think that I am going to do that as soon as I returned to the States.
Old 02-05-18, 06:33 PM
  #49
Acrad
Super Moderator
Acrad's Avatar
Some of my skid control ECU/Master cylinder version concerns are less now. Found this on someone trying to convert an FJ. It lacks the Driver Support Computer so a different animal getting it working there but on this post it seems the skid control ECU attached to the master cylinder is possibly informed by the "Driver Support computer" of vehicle capabilities. In this instance after a master cylinder is replaced or the calibration reset has been performed.
https://www.justanswer.com/toyota/98...ght-stays.html
Old 02-05-18, 08:33 PM
  #50
hzhao
hzhao's Avatar
So, if i am understanding correctly, on most of GX, the Downhill Assist is already exist, then it is not necessary to even do zero point for skid control EUC at all. since all the sensors and yaw control are all have been calibrated. Right? All it might need to do is the calibration of Crawl Control part......
Old 02-05-18, 08:43 PM
  #51
Acrad
Super Moderator
Acrad's Avatar
On all GXs without crawl control they should have the DAC calibration profile in effect. Crawl Control models have their own calibration profile. DAC and CC can't coexist so in order to migrate to the CC calibration you have to erase the DAC one. In that Prado thread it seem if I plug in 859A1-60020 the MTS option will be available in dash menu but it actually won't don't anything since the calibration for CC isn't live. Not sure if 84970-60070 has to also be plugged in. Not sure how the camera stuff will work with MTS since that will be absent but is activated when in effect.
Old 02-05-18, 09:04 PM
  #52
hzhao
hzhao's Avatar
That's what I thought, no need for zero points calibration, but just the Crawl Control Calibration.
Old 02-06-18, 02:10 PM
  #53
Acrad
Super Moderator
Acrad's Avatar
I guess we'll find out soon enough... I thought I saw posts on .ru sites that many weren't successful unless you blew existing configs away and calibrated everything at once. It didn't take well to an incremental update apparently.
The guy that converted his 4Runner said in article
"Once everything is hooked up and back in place, you will need to do a Memory Reset for the Skid Control ECU, then a Crawl Control Calibration and Zero Point Calibration. It is important to do the memory reset otherwise the crawl control calibration will not work.
Old 02-08-18, 04:04 PM
  #54
Acrad
Super Moderator
Acrad's Avatar
I'm thinking the skid ecu might squash this mod but we'll see. I plan to try it.. if it fails I'll plug everything back in and recalibrate for DAC. At $1500 price point for all parts here I'd be looking for air locker options.
The '10s got their skid-ECU flashed for the recall.
http://www.revbase.com/BBBMotor/TSb/...dPdf?id=196186
"Flash reprogramming allows the ECU software to be updated without replacing the ECU. Flash calibration updates for specific vehicle models/ECUs are released as field-fix procedures described in individual Service Bulletins. This bulletin details the Techstream ECU flash reprogramming process and outlines use of the Technical Information System (TIS) and the Calibration Update Wizard (CUW). Flash calibration updates can only be applied to the vehicle/ECU combination for which they are intended. ECUs have internal security that will not allow them to be programmed with another ECU’s information."
Old 02-08-18, 04:28 PM
  #55
hzhao
hzhao's Avatar
Let's keep our fingers crossed on this one. The way I am reading it, is it more of the "update" only apply to specific vehicle/EUC combination for its intended to. Not sure if that applies when we do the zero calibration and others. You are right, we'll find out soon.
Old 02-09-18, 12:33 PM
  #56
Acrad
Super Moderator
Acrad's Avatar
I was fully reading through that long 138 or so page Russian thread last night and noticed a few things
• There a few models of Prado that either are not compatible or even lack the wiring
• In other markets they appear to unwind the options further. If some countries there are models without crawl & MTS but Radar cruise is present. Apparently this model that comes with radar cruise can't or hasn't been retrofitted yet.
• It does appear to come down to the skid control ECU but since no one has publicly posted about converting a GX 460 "for crawl" we don't know yet. My 020 module shipped from Japan today. Still waiting on the console switch.
Old 02-11-18, 05:36 AM
  #57
Acrad
Super Moderator
Acrad's Avatar
Here are Techstream ECU reflash instructions
File Type: pdf
Old 02-11-18, 01:56 PM
  #58
Acrad
Super Moderator
Acrad's Avatar
EDIT: I will start a list here in this post. I'm gonna do the full model range as this may be important in the future. I'm pulling in what I see from eBay & wrecking yards as well. I'll note those as those may not be correct.
2010 - Base / 89541-60190 (wrecking yard) AKA 4705060200
2010 - Premium / 89541-60190 - AKA 4705060200
2010 - Premium with Crawl Control
2010 - Premium with Crawl Control (Canada) / 89541-60070 - AKA 4705060220
2011 - Base / 89541-60191 (2 reports) / 89541-60061 (eBAY) - AKA 4705060201
2011 - Premium
2011 - Premium with Crawl Control
2012 - Base
2012 - Premium / 89541-60350
2012 - Premium with Crawl Control
2013 - Base / 89541-60510
2013 - Premium / 89541-60510 (wrecking yard)
2013 - Premium with Crawl Control
2014 - Base
2014 - Premium / 89541-60630 (wrecking yard)
2014 - Luxury
2014 - Luxury w/Driver Support
2015 - Base
2015 - Premium / 89541-60630 (eBay)
2015 - Luxury
2015 - Luxury w/Driver Support
2016 - Base
2016 - Premium / 89541-60631 (wrecking yard)
2016 - Luxury
2016 - Luxury w/Driver Support / 89541-60662
2017 - Base
2017 - Premium
2017 - Luxury
2017 - Luxury w/Driver Support
2018 - Base
2018 - Premium
2018 - Luxury
2018 - Luxury w/Driver Support
Looking for '10-'13 Base, Premium and Premium w/Driver Support skid control ECU #'s. All trims and years '10-'13.
I am curious if they changed PN's on all model years and trims. This is the black box attached the brake master cylinder that has brand name Advic. The number above bar code is the model#. Mine is 89541-60350.
Steve from the 4Runner conversion is helping me with some research on this too.
Thanks!
Old 02-11-18, 02:03 PM
  #59
Acrad
Super Moderator
Acrad's Avatar
Steve pointed me to this site if re-flash ends up being needed. I will be reaching out to them for thoughts as well.
http://artsautomotive.com/publicatio...h-toyota-ecus/
Repair – We Can Flash Toyota ECUs
In 2005, Toyota promised “an era of unprecedented cooperation with independent repair shops”. Part of this new philosophy is providing access to all of the tools and information available to dealership mechanics to independent mechanics. Information in the form of repair manuals, technical service bulletins, campaigns, and even Toyota’s dealer training programs can be accessed through Toyota’s TIS website. Special tools and software can also be ordered through TIS.
Reprogramming the ECU (engine control unit) is one of the repairs we’ve had to send to a dealer in the past. Without the software and the tool to do the reprogramming, an independent, no matter how well trained, can not do an ECU update. Thanks to Toyota’s excellent new attitude, we’ve been able to buy the factory scan tool and software and we can install ECU updates here at Art’s Automotive! This is a Rav4 that had a check engine light and a code P0420 (catalyst efficiency code). There was not a problem with the catalytic converter, the computer was simply being over-critical in it’s analysis of the converter’s performance. Toyota realized there was a problem, rewrote the monitoring software, had it approved by the US EPA and the California Air Resources Board, then made it available to dealers and independent shops via download or CD. Failing to follow the reprograming instructions carefully can make a paperweight of a $800 computer, so it’s not a job for impatient mechanics or Toyota novices.
Having the factory scan tool also provides access to more information and testing capabilities than are available using a generic OBDII scanner. OBDII is a specification for access to diagnostic information from the ECU. All manufacturers must meet the minimum requirements of the OBDII specification. However, manufacturers also add proprietary diagnostic capabilities to their computer control systems that are accessible only with the factory scanner. Toyota’s willingness to sell the scanner and scanner software to us has made our job a lot easier. Systems inaccessible with a generic scanner, like SRS (air bag), ABS (anti-lock brakes), and many others can be inspected using the MasterTech. There are also many bi-directional tests that can be performed to quickly check system operation without disassembly and hands on inspection. Anything that saves time while paying for by-the-hour diagnosis makes everyone happy.
Old 02-11-18, 06:04 PM
  #60
Acrad
Super Moderator
Acrad's Avatar
Looks like my CC console switch just shipped from UAE... the 020 left Tokyo on the 10th.
Quick Reply: MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
