View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2010 - Base - Added Crawl/MTS
0.81%
2010 - Premium - Added Crawl
0.81%
2010 - Premium - Added Crawl/MTS
1.63%
2010 - Premium (stock Crawl) - Added MTS
3.25%
2011 - Base - Added Crawl
0%
2011 - Base - Added Crawl/MTS
4.07%
2011 - Premium - Added Crawl
1.63%
2011 - Premium - Added Crawl/MTS
2.44%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Base - Added Crawl/MTS
2.44%
2012 - Premium - Added Crawl
0.81%
2012 - Premium - Added Crawl/MTS
4.88%
2012 - Premium (stock Crawl) - Added MTS
0%
2013 - Base - Added Crawl
0.81%
2013 - Base - Added Crawl/MTS
4.07%
2013 - Premium - Added Crawl
0.81%
2013 - Premium - Added Crawl/MTS
5.69%
2013 - Premium (stock Crawl) - Added MTS
1.63%
2014 Base - Added Crawl
0%
2014 Base - Added Crawl/MTS
3.25%
2014 Premium - Added Crawl
0.81%
2014 Premium - Added Crawl/MTS
4.07%
2014 Luxury - Added Crawl
0.81%
2014 Luxury - Added Crawl/MTS
3.25%
2014 Luxury (stock Crawl)- Added MTS
4.88%
2015 Base - Added Crawl
0%
2015 Base - Added Crawl/MTS
2.44%
2015 Premium - Added Crawl
0%
2015 Premium - Added Crawl/MTS
1.63%
2015 Luxury - Added Crawl
0.81%
2015 Luxury - Added Crawl/MTS
0.81%
2015 Luxury (stock Crawl)- Added MTS
0.81%
2016 Base - Added Crawl
0%
2016 Base - Added Crawl/MTS
4.07%
2016 Premium - Added Crawl
0%
2016 Premium - Added Crawl/MTS
4.07%
2016 Luxury - Added Crawl
1.63%
2016 Luxury - Added Crawl/MTS
0.81%
2016 Luxury (stock Crawl)- Added MTS
0.81%
2017 Base - Added Crawl
0%
2017 Base - Added Crawl/MTS
3.25%
2017 Premium - Added Crawl
0%
2017 Premium - Added Crawl/MTS
2.44%
2017 Luxury - Added Crawl
0.81%
2017 Luxury - Added Crawl/MTS
0%
2017 Luxury (stock Crawl)- Added MTS
7.32%
2018 Base - Added Crawl
0%
2018 Base - Added Crawl/MTS
0.81%
2018 Premium - Added Crawl
0.81%
2018 Premium - Added Crawl/MTS
4.07%
2018 Luxury - Added Crawl
0%
2018 Luxury - Added Crawl/MTS
0.81%
2018 Luxury (stock Crawl)- Added MTS
0.81%
2019 Base - Added Crawl
0%
2019 Base - Added Crawl/MTS
0.81%
2019 Premium - Added Crawl
0%
2019 Premium - Added Crawl/MTS
4.88%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
2019 Luxury (stock Crawl)- Added MTS
2.44%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
Old 07-03-18, 10:19 AM
  #646
Acrad
Super Moderator
Acrad's Avatar
Received 3,638 Likes on 2,383 Posts
Originally Posted by Jacket
I bugged them a couple times this week via email, and never got a response, but I did finally get a tracking number.
Does tracking show it in the states yet?
Old 07-03-18, 10:45 AM
  #647
Jacket
Jacket's Avatar
I did get the package. Not sure if my emails helped bring attention back to it, but once the tracking number dropped it was around a week to get from Dubai to my door.
The following 2 users liked this post by Jacket:
Acrad (07-03-18), KJ6IRM (07-09-18)
Old 07-12-18, 07:06 PM
  #648
Jacket
Jacket's Avatar
Got the Crawl switch installed and calibrated tonight. I went with the @Nickk6 method of keeping the blanks for the top two buttons, and having "stealth crawl" under the guise of a DAC switch.
Old 07-12-18, 07:11 PM
  #649
Jacket
Jacket's Avatar
And did a test run by "Crawling" up my driveway and into the garage.
Acrad (07-13-18)
Old 07-12-18, 07:17 PM
  #650
R3loader
R3loader's Avatar
Nice. I also receive my console switch and MTS computer. I need to find time to get it installed. Do i have to do calibration for the MTS as well?
Old 07-12-18, 07:20 PM
  #651
Jacket
Jacket's Avatar
I didn't. Installed the new computer, reconnected the battery, and MTS was there when I started the GX.
Old 07-12-18, 07:29 PM
  #652
R3loader
R3loader's Avatar
Great. I will try to get it done this weekend. How long would you say the MTS computer took you with the globe box removal, etc.
Old 07-12-18, 09:54 PM
  #653
Jacket
Jacket's Avatar
Probably about an hour, but I had taken apart a lot of those parts before so I just dove right in. The lower kick panel below the box is a bit tricky and the clips are pretty tight. I didn't remove the whole thing - just enough to get the interior of the glove box out of the way so I could stick my hand in there to unbolt the old computer. Budget a couple hours if you haven't been in there already.
Old 07-13-18, 01:06 AM
  #654
Acrad
Super Moderator
Acrad's Avatar
The remote start install instructions are also a good tutorial for taking dash apart. The remote start module is installed to the right of the Driver Support ECU
https://www.clublexus.com/forums/att...t-ac6a39f2.pdf
Old 07-13-18, 04:54 AM
  #655
R3loader
R3loader's Avatar
Thanks guys. I plan to add then this weekend.
Old 07-17-18, 04:12 PM
  #656
R3loader
R3loader's Avatar
Got the MTS computer installed and the console switch swapped. Is there a trick to install the passenger kick panel? Also, I have not had a chance to calibrate for the new switch, would there be a problem driving the car before calibration?
Old 07-17-18, 06:45 PM
  #657
Acrad
Super Moderator
Acrad's Avatar
Do you have a picture of where things aren't meshing up? Only tricky part I had was removing the knee air bag.
It should be fine driving without calibration. You just wouldn't be able to use DAC.
Old 07-18-18, 06:44 AM
  #658
R3loader
R3loader's Avatar
I was able to put on the kick panel this morning. When I took it off, I removed the clip and forgot how it goes back on. I finally figured it out. I will try to calibrate it tonight.
Old 07-19-18, 12:46 PM
  #659
R3loader
R3loader's Avatar
got the car calibrated but something weird is happening. The VDC light is on constantly. I try to activate the crawl control but the on/off switch does nothing. The sequence I use is to put the car in Neutral, put car in 4lo, then shift into Drive and turn on Crawl button but it does nothing. I might have to calibrate again. Has anyone ran into this before? MTS is recognized and I could set the car in different terrains.
Old 07-19-18, 02:31 PM
  #660
Acrad
Super Moderator
Acrad's Avatar
That sounds like an incomplete calibration. MTS will work separate from Crawl.
Quick Reply: MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
