Menwir: I actually pulled out glove box a little more than you but I did leave the lower airbag about the same amount out. I needed to subsequently remove everything for a OEM remote start install on my '12. My big hands needed the glovebox a lot further out though.
[QUOTE=Acrad35751;10291212]Menwir: I actually pulled out glove box a little more than you but I did leave the lower airbag about the same amount out. I needed to subsequently remove everything for a OEM remote start install on my '12. My big hands needed the glovebox a lot further out
I just installed the CC in my GX and I did the same what in the instruction but the KDSS ABS and Sliping indicator continued to flash. I guess I did something wrong. (By using paper clips). can someone help me with that. The CC looks too slow that's why I want to do the calibration or the reset again because the speed all of them have the same speed.
Sounds like zero point didn't take. A few here have done the paper clip method.
I just got the ECU today why does it look different than the one in earlier posts
Why does it look different than the one in earlier posts
I don't see much of differences other than the product label color (black vs. white). Physical shape is about same as well. I won't expecting anything different in functions.
