13 GX460 BASE, Success, MTS and Crawl in that order , OBD method, no techstream, ops checks good, be sure to turn CC on and of before closeout with this method also! THX to all who make these things possible!
Take a look at first post and diagrams you will see Driving Support Switch to the left. This is for the MTS
on a side note to all... I guess one member on GXOR got their dealer to install both pieces and a zero point. Just something to think about for those uncomfortable doing this themselves.
Thanks guys for your support I added CC to my car and I tried in sand and it was great 🤗
Thanks for all the support and help! One recommendation for all the people trying to do this mod, is don’t try to remove the knee air bag it’s not necessary. Just remove the screw on the bottom left corner gives you play. After that it comes loose and take off the glove box screws and the glove box light. Good luck I am no pro at this. it was my first time doing anything of this sort following the instructions and being careful not to break any clips or pull any cables.
I appreciate all the info you guys provided. I've '10 GX460 and I would like to add CC + MTS.
After I check the 1st post and jp/middle east part's providers(both run out CC switch), Is there any other CC switch provider(China?) that ask less jack up price(I saw Acrad35751 post around $200 CC switch part)?
Besides, is there anyone use dealer to do the zero cal? and how much they charged(1 hr labor)?
I didn't get the dealer but someone on GXOR mentioned they had someone install Driver Support module, CC switch and Zero point. Not sure of cost. I guess they couldn't get it to work right away so pointed the dealer back at this thread and got it working. It's a quick procedure and not sure what minimum time a dealership would charge. I imagine .25 hour increments are minimum but do dealers have initial one hour minimum time too?
