View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2011 - Base - Added Crawl
0%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Premium (stock Crawl) - Added MTS
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 125. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#811
HELP! My GX cannot start after I added crawl control
Hi all. I was following the tutorial on this forum to install MTS + crawl control to my 2014 GX. A few weeks ago I installed MTS and everything worked perfectly. Today I installed the crawl control module and then did the zero point calibration with techstream. Once I completed the zero point calibration I started the car, but then I heard rapid vibration under the hood and it seems the engine was not started. I then immediately turned off the ignition. After connecting to techstream for several times I got error code C120A and C1241. C120A was always there and C1241 could be cleared. I tried resetting the memory and starting the test mode for multiple times but that didn't help.
What's even worse is that right now the GX doesn't respond no matter how I pressed the ignition. After the first click there is nothing on the dashboard. After the second click there is only a check engine light with the break pedal vibrating. I cannot event connect to the ABS ECU with techstream! It said something like "the unit does not respond"! I also disconnected my battery but that also didn't help. My GX almost died!!!
I don't have much experience in techstream though. Is it something that I could resolve by myself, or I have to get someone from the repair shop? Any help is appreciated! Thanks!
#812
Sorry to hear this.
C1241 is low voltage warning, it could be the battery.
C120A could means the ZPC wasn’t completed.
When you completed the ZPC, was you able to activate Crawl successfully and in 4-lo?
Some info in C120A from 4runner forum
https://www.toyota-4runner.org/5th-g...libration.html
#813
Sorry to hear this.
#814
Do you have access to a new battery to test? maybe costco? When I add Crawl to mine I did it with the engine running.
Maybe a weak battery threw off the code?
#815
The symptoms you describe sounds like a dead battery in modern Toyota’s I’ve encountered with the buzzing pedal. You should check the battery voltage or get a new battery in there. How long did you leave the ignition on for?
#816
Super Moderator
It does sound like a possible bad or discharged battery. Do you have access to a battery charger or something to jump the car with?
#817
Super Moderator
Super Moderator
Just an enthusiast like the rest of us here :-)
Hopefully all the info we have gathered here and elsewhere will help support the vehicle for decades to come.
#819
how much are you asking for it? Was looking to do this when tax return comes in.
#821
make sure to read the book on changing the battery. on some years, a simple sounding battery swap can cause all sorts of damage if done with certain incorrect methods
#823
My GX is alive
Thank you all for all the helps!!! My GX is alive again!
It was because the battery was dead. I jump started the GX and redid the zero point calibration, and now I am another GX owner with MTS + crawl control :P The "wheels" on the dashboard didn't show up until I drove it straight for a while.
It was weird though since last night I was able to start the engine right before I did the ZPD, and the ZPD only took 5 minutes. I would encourage everyone to do it with engine ON whenever possible.
#824
Super Moderator
Good to hear!!
What year GX do you have?
Totally normal on the wheels not showing up until you drive straight 200-300 feet over 25 MPH.
