View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2010 - Base - Added Crawl/MTS
0.81%
2010 - Premium - Added Crawl
0.81%
2010 - Premium - Added Crawl/MTS
1.63%
2010 - Premium (stock Crawl) - Added MTS
3.25%
2011 - Base - Added Crawl
0%
2011 - Base - Added Crawl/MTS
4.07%
2011 - Premium - Added Crawl
1.63%
2011 - Premium - Added Crawl/MTS
2.44%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Base - Added Crawl/MTS
2.44%
2012 - Premium - Added Crawl
0.81%
2012 - Premium - Added Crawl/MTS
4.88%
2012 - Premium (stock Crawl) - Added MTS
0%
2013 - Base - Added Crawl
0.81%
2013 - Base - Added Crawl/MTS
4.07%
2013 - Premium - Added Crawl
0.81%
2013 - Premium - Added Crawl/MTS
5.69%
2013 - Premium (stock Crawl) - Added MTS
1.63%
2014 Base - Added Crawl
0%
2014 Base - Added Crawl/MTS
3.25%
2014 Premium - Added Crawl
0.81%
2014 Premium - Added Crawl/MTS
4.07%
2014 Luxury - Added Crawl
0.81%
2014 Luxury - Added Crawl/MTS
3.25%
2014 Luxury (stock Crawl)- Added MTS
4.88%
2015 Base - Added Crawl
0%
2015 Base - Added Crawl/MTS
2.44%
2015 Premium - Added Crawl
0%
2015 Premium - Added Crawl/MTS
1.63%
2015 Luxury - Added Crawl
0.81%
2015 Luxury - Added Crawl/MTS
0.81%
2015 Luxury (stock Crawl)- Added MTS
0.81%
2016 Base - Added Crawl
0%
2016 Base - Added Crawl/MTS
4.07%
2016 Premium - Added Crawl
0%
2016 Premium - Added Crawl/MTS
4.07%
2016 Luxury - Added Crawl
1.63%
2016 Luxury - Added Crawl/MTS
0.81%
2016 Luxury (stock Crawl)- Added MTS
0.81%
2017 Base - Added Crawl
0%
2017 Base - Added Crawl/MTS
3.25%
2017 Premium - Added Crawl
0%
2017 Premium - Added Crawl/MTS
2.44%
2017 Luxury - Added Crawl
0.81%
2017 Luxury - Added Crawl/MTS
0%
2017 Luxury (stock Crawl)- Added MTS
7.32%
2018 Base - Added Crawl
0%
2018 Base - Added Crawl/MTS
0.81%
2018 Premium - Added Crawl
0.81%
2018 Premium - Added Crawl/MTS
4.07%
2018 Luxury - Added Crawl
0%
2018 Luxury - Added Crawl/MTS
0.81%
2018 Luxury (stock Crawl)- Added MTS
0.81%
2019 Base - Added Crawl
0%
2019 Base - Added Crawl/MTS
0.81%
2019 Premium - Added Crawl
0%
2019 Premium - Added Crawl/MTS
4.88%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
2019 Luxury (stock Crawl)- Added MTS
2.44%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
Old 03-09-19, 03:25 PM
  #856
Acrad
Super Moderator
Acrad's Avatar
Received 3,638 Likes on 2,383 Posts
Originally Posted by ltsr
I recently installed crawl and used techstream to do the zero point calibration. I also used my MacBook Pro with virtual box running windows 7 64bit. I just searched around and got it all working just fine. I would say getting techstream running on that took the longer than actually doing the zpc.
This link might speed it up for others in the future as well
Old 03-09-19, 04:51 PM
  #857
r2m
r2m's Avatar
I keep reading about having to do this re-calibration.
Time for a stupid question: Why does one need to do the re-calibration? Does it have something to do with the anti-lock brakes? Or??
Old 03-09-19, 05:05 PM
  #858
Acrad
Super Moderator
Acrad's Avatar
You have to let the Skid Control ECU attached to the master cylinder know that the vehicle is equipped with crawl control. I surmise it is akin to selecting a different software profile in that ECU as well. The first part of the process is erasing the current DAC profile. The connector pins used for DAC versus SPEED are different and as the last piece of the calibration you trigger the speed switch to let vehicle know/learn it is equipped with crawl and then crawl profile is selected. If you ever want to revert back to DAC you do the same process all over again except with the DAC switch installed. Hope this helps some
r2m (03-09-19)
Old 03-10-19, 11:01 PM
  #859
venomixia
venomixia's Avatar
Originally Posted by Acrad35751
84970-60070 should be the console switch for all GXs. This gets you Crawl Control.
MTS requires changing a module behind the glove box. For '10-'13 that PN is 859A1-60020
The 14+ it may be 859A1-60040..
https://www.clublexus.com/forums/gx-...l#post10096363
https://www.youtube.com/watch?v=-oLFU7C3TAc
Haha i love this video. The guy in the yellow shirt said "having a good gun isn't necessary if the shooter knows how to shoot" lmaooooooo
Old 03-10-19, 11:06 PM
  #860
venomixia
venomixia's Avatar
Originally Posted by hzhao
Most Lexus dealers probably WILL NOT do the service due to liability issue when modification involves "out of spec" for the vehicle which is not "approved" in specific market. If you would bring a vehicle to dealer for "zero point calibration", the chances are they will either refuse to do, or only do it with original configured parts. You may know someone as a personal friend that willing to do it as a personal favor.
Just imagine, in today's reality, they did all the calibration, you drove off and involves an accident which was due to some fashion of ABS didn't work right, dealer and/or Lexus could be held responsible because they "contributed" an out of spec vehicle which has not been proved to sell in this market.
Hzhao, did you try Metro Lexus in Brook Park? I know some people there and I hope they'd be able to help - I just don't know what exactly to ask for.
Old 03-11-19, 09:27 AM
  #861
hzhao
hzhao's Avatar
I have been with Metro Lexus since 1993. I have to say that I am a very happy customer of Metro Lexus and received best service experiences from them ever since. If you do know individuals there in person, and there is nothing wrong to ask. All you have to do is asking for them to replace the Driver Assist Switch module which is right behind glove box. There is no other software setup needs to be performed for that one. If you go further with CC switch replacement, there a zero calibration will have to be done. During the airbag recall process, both glove box and center stack of radio and nav screen units will be removed. If your contact in Metro is willing to do that for you, would be ideal time to do them all. And worst answer from Metro would be "No". Since you are in the area, feel free to let me know if I can give you a hand for the mod if Metro couldn't do it due to liability fact.
venomixia (03-11-19)
Old 03-11-19, 12:35 PM
  #862
venomixia
venomixia's Avatar
Thanks, I really appreciate. I'm gonna order the part tomorrow and find out if they can do it when it comes in. My recall was already completed, so I'd have to see if I can get it done during one of my service intervals and pay the service tech a little extra if it comes to that.
Old 03-11-19, 12:54 PM
  #863
hzhao
hzhao's Avatar
Good luck! And do let us know how it went.
Old 03-14-19, 09:32 AM
  #864
oksir83
oksir83's Avatar
Well, I was going to install my MTS today but this isn't going to work. I'm 0/2 on receiving incorrect or missing parts this week from different sources. I swear online retailers are just getting lazy.
Old 03-14-19, 09:37 AM
  #865
bbqsoup
bbqsoup's Avatar
You got an engine mount? Where did you order it?
Old 03-14-19, 09:44 AM
  #866
oksir83
oksir83's Avatar
Yup, lol. I ordered from the site in the original post Oemvehicleparts. It was just thrown into a previous used padded envelope as well. Hopefully they take more care shipping an electrical component.
Old 03-14-19, 10:11 AM
  #867
bbqsoup
bbqsoup's Avatar
That was strange. Did you order using VIN or just part number. That was a big goof up on their end.
You can send an email to Matt and probably ask for expediting shipping for the replacement.
Old 03-14-19, 10:20 AM
  #868
oksir83
oksir83's Avatar
Ordered by p/n...no mention of VIN in my order. I realize things happen, but it just hasn't been my week. Prinsu also left parts of my rack out of the box and I'm still waiting on those to get to me. I own an e-commerce site as well, so maybe I'm a bit more critical. At the end of the day, it really isn't that hard to check a pack list against a box, especially if there is only supposed to be 1 part in the box.
Old 03-14-19, 11:07 AM
  #869
oksir83
oksir83's Avatar
I just got off the phone w/ Matt @ OEMVehicleparts (he reached out to me in response to my e-mail to him, which was appreciated) and we're getting it all straightened out. Hopefully I didn't unnecessarily tarnish anyone's name, just had to vent my frustrations w/o thinking clearly first. I had an exciting week of mods planned for my new GX and it has turned out to be pretty lackluster.
The following 2 users liked this post by oksir83:
Acrad (03-14-19), bbqsoup (03-14-19)
Old 03-23-19, 08:25 AM
  #870
Acrad
Super Moderator
Acrad's Avatar
Matt says he has a lot of 040 and 070s in stock if one wants to get one quickly.
Wonder if we have cracked a couple hundred yet doing these mods?
Quick Reply: MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
