View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2010 - Base - Added Crawl/MTS
0.81%
2010 - Premium - Added Crawl
0.81%
2010 - Premium - Added Crawl/MTS
1.63%
2010 - Premium (stock Crawl) - Added MTS
3.25%
2011 - Base - Added Crawl
0%
2011 - Base - Added Crawl/MTS
4.07%
2011 - Premium - Added Crawl
1.63%
2011 - Premium - Added Crawl/MTS
2.44%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Base - Added Crawl/MTS
2.44%
2012 - Premium - Added Crawl
0.81%
2012 - Premium - Added Crawl/MTS
4.88%
2012 - Premium (stock Crawl) - Added MTS
0%
2013 - Base - Added Crawl
0.81%
2013 - Base - Added Crawl/MTS
4.07%
2013 - Premium - Added Crawl
0.81%
2013 - Premium - Added Crawl/MTS
5.69%
2013 - Premium (stock Crawl) - Added MTS
1.63%
2014 Base - Added Crawl
0%
2014 Base - Added Crawl/MTS
3.25%
2014 Premium - Added Crawl
0.81%
2014 Premium - Added Crawl/MTS
4.07%
2014 Luxury - Added Crawl
0.81%
2014 Luxury - Added Crawl/MTS
3.25%
2014 Luxury (stock Crawl)- Added MTS
4.88%
2015 Base - Added Crawl
0%
2015 Base - Added Crawl/MTS
2.44%
2015 Premium - Added Crawl
0%
2015 Premium - Added Crawl/MTS
1.63%
2015 Luxury - Added Crawl
0.81%
2015 Luxury - Added Crawl/MTS
0.81%
2015 Luxury (stock Crawl)- Added MTS
0.81%
2016 Base - Added Crawl
0%
2016 Base - Added Crawl/MTS
4.07%
2016 Premium - Added Crawl
0%
2016 Premium - Added Crawl/MTS
4.07%
2016 Luxury - Added Crawl
1.63%
2016 Luxury - Added Crawl/MTS
0.81%
2016 Luxury (stock Crawl)- Added MTS
0.81%
2017 Base - Added Crawl
0%
2017 Base - Added Crawl/MTS
3.25%
2017 Premium - Added Crawl
0%
2017 Premium - Added Crawl/MTS
2.44%
2017 Luxury - Added Crawl
0.81%
2017 Luxury - Added Crawl/MTS
0%
2017 Luxury (stock Crawl)- Added MTS
7.32%
2018 Base - Added Crawl
0%
2018 Base - Added Crawl/MTS
0.81%
2018 Premium - Added Crawl
0.81%
2018 Premium - Added Crawl/MTS
4.07%
2018 Luxury - Added Crawl
0%
2018 Luxury - Added Crawl/MTS
0.81%
2018 Luxury (stock Crawl)- Added MTS
0.81%
2019 Base - Added Crawl
0%
2019 Base - Added Crawl/MTS
0.81%
2019 Premium - Added Crawl
0%
2019 Premium - Added Crawl/MTS
4.88%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
2019 Luxury (stock Crawl)- Added MTS
2.44%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
Old 07-27-19, 06:43 AM
  #886
Acrad
Super Moderator
Acrad's Avatar
Received 3,638 Likes on 2,383 Posts
GXOR member found this 2010 unicorn. I haven't seen this setup before so not sure if it came out of Canada or another market at the time. I've also not run across this crawl switch version.
This is a 2010 base that is equipped with crawl and the wide view front and side monitor but lacks radar cruise/PCS. There are some references in the 2010-2013 brochures that indicate some of these options like crawl could be standalone. I have just never seen one in the wild. I somehow missed this video.
EDIT: I wonder if this switch is the 84970-60090?
EDIT2: GXOR member has ordered one so we will find out if it is the real deal. Apparently none in the US so will need to come from Japan I assume.
ltsr (07-27-19)
Old 08-05-19, 04:05 AM
  #887
Acrad
Super Moderator
Acrad's Avatar
I missed this in 10-11 brochures as a possible package in these years that included just cameras, crawl and PA. Trim isn't specified so this could have included both base and premium. GXOR member has a '10 Premium optioned this way without radar cruise, PCS, etc. Option disappears in '12 brochure. Still looking into this interesting crawl switch pictured above.
Old 08-14-19, 02:11 PM
  #888
klinquist
klinquist's Avatar
Originally Posted by Nickk6
Heres a night shot, looks like the switches all light up.
Hey Nikk6,
I noticed your switch still says DAC.. did you just move the on/off button over to your existing switch assembly?
why not just move the blank plates over to the new switch assembly? I want mine to say SPEED... What am I missing?
Old 08-14-19, 02:22 PM
  #889
Acrad
Super Moderator
Acrad's Avatar
Unfortunately that is all one piece on the 070 crawl switch. There is still hope on the 090 in posts further up as I hear a 100 was sent because VIN was put in at order time. Need to make sure not to put a VIN# in when ordering.
Inside of a stock 080
Old 08-14-19, 03:30 PM
  #890
klinquist
klinquist's Avatar
Right- the first picture you posted - can't you just pop the top 2 blanks off of the stock switch (assuming no adj.suspension), put them on 070, and plug it in?
Old 08-14-19, 03:37 PM
  #891
Acrad
Super Moderator
Acrad's Avatar
That is a good point. Unless I am not thinking of something else that should work.
Old 08-14-19, 03:55 PM
  #892
klinquist
klinquist's Avatar
If all goes well, picking up a GX on Sat. Will order the switch on Monday and post results when I get it .
Acrad (08-14-19)
Old 08-14-19, 04:02 PM
  #893
Acrad
Super Moderator
Acrad's Avatar
I was trying to think why this hadn't been done but you would have to cut the switch covers (old and new) in half. Cut 070 and 100 covers in half and remove the top two switches from the 070.
Top cover of 100 and bottom cover of 070 used.
Not sure if this then sits loose at all.
EDIT: I've asked Matt@OEM how long it will be before we see the 090. This could open up some options to those who planned to install crawl on models without AVS/RAHC and didn't want the two dummy switches. Still up in the air if 090 is this elusive switch version.
Old 08-14-19, 04:20 PM
  #894
klinquist
klinquist's Avatar
aah gotcha, I think you are saying that the blanks don't just pop off, they are molded into the surround.
There is an 090 on ebay, hm..
Old 08-14-19, 04:24 PM
  #895
Acrad
Super Moderator
Acrad's Avatar
I’d wait on the 090 at moment as we don’t know yet if it is the same as the 100. Matt will let me know tomorrow an approximate ETA for the 090 on order. They might be blowing the dust off this switch at foreign parts depot.
Old 08-15-19, 07:32 PM
  #896
klinquist
klinquist's Avatar
Another idea I just got... maybe I order the 070 switch and see if I can hack CAN bus messages to use the switches to turn on auxiliary LEDs or something .
Old 08-16-19, 03:32 AM
  #897
Acrad
Super Moderator
Acrad's Avatar
That would be a cool mod if you could pull it off. I’m hearing that 090 won’t be seen until early September.
Old 08-20-19, 09:05 AM
  #898
Acrad
Super Moderator
Acrad's Avatar
This hasn't been installed and tested yet but looks like the 090 is that unicorn Crawl switch for non-AVS/RAHC models. Here are a few pictures kindly shared by GXOR member who purchased the switch. I will begin updating Wiki and this thread. No confirmed installs yet but really no reason to believe this won't retrofit like the 070.
$269.67
https://www.oemvehicleparts.com/oem-...tch-8497060090
PN: 84970-60090
The following 4 users liked this post by Acrad:
bbqsoup (08-20-19), hzhao (08-20-19), klinquist (08-20-19), ltsr (08-20-19)
Old 08-20-19, 06:54 PM
  #899
nebrou
nebrou's Avatar
I have went through 55 pages but I cannot confirm if I still need to replace the whole control switch if I have premium 2012 GX 460 (4 toggle switches with DAC) or do I still need to replace it to get Crawl Control feature?
Old 08-20-19, 06:57 PM
  #900
Acrad
Super Moderator
Acrad's Avatar
First post... need the 070 switch and whole switch assembly is replaced
https://www.oemvehicleparts.com/oem-...tch-8497060070
nebrou (08-21-19)
Quick Reply: MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
