View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2010 - Base - Added Crawl/MTS
0.81%
2010 - Premium - Added Crawl
0.81%
2010 - Premium - Added Crawl/MTS
1.63%
2010 - Premium (stock Crawl) - Added MTS
3.25%
2011 - Base - Added Crawl
0%
2011 - Base - Added Crawl/MTS
4.07%
2011 - Premium - Added Crawl
1.63%
2011 - Premium - Added Crawl/MTS
2.44%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Base - Added Crawl/MTS
2.44%
2012 - Premium - Added Crawl
0.81%
2012 - Premium - Added Crawl/MTS
4.88%
2012 - Premium (stock Crawl) - Added MTS
0%
2013 - Base - Added Crawl
0.81%
2013 - Base - Added Crawl/MTS
4.07%
2013 - Premium - Added Crawl
0.81%
2013 - Premium - Added Crawl/MTS
5.69%
2013 - Premium (stock Crawl) - Added MTS
1.63%
2014 Base - Added Crawl
0%
2014 Base - Added Crawl/MTS
3.25%
2014 Premium - Added Crawl
0.81%
2014 Premium - Added Crawl/MTS
4.07%
2014 Luxury - Added Crawl
0.81%
2014 Luxury - Added Crawl/MTS
3.25%
2014 Luxury (stock Crawl)- Added MTS
4.88%
2015 Base - Added Crawl
0%
2015 Base - Added Crawl/MTS
2.44%
2015 Premium - Added Crawl
0%
2015 Premium - Added Crawl/MTS
1.63%
2015 Luxury - Added Crawl
0.81%
2015 Luxury - Added Crawl/MTS
0.81%
2015 Luxury (stock Crawl)- Added MTS
0.81%
2016 Base - Added Crawl
0%
2016 Base - Added Crawl/MTS
4.07%
2016 Premium - Added Crawl
0%
2016 Premium - Added Crawl/MTS
4.07%
2016 Luxury - Added Crawl
1.63%
2016 Luxury - Added Crawl/MTS
0.81%
2016 Luxury (stock Crawl)- Added MTS
0.81%
2017 Base - Added Crawl
0%
2017 Base - Added Crawl/MTS
3.25%
2017 Premium - Added Crawl
0%
2017 Premium - Added Crawl/MTS
2.44%
2017 Luxury - Added Crawl
0.81%
2017 Luxury - Added Crawl/MTS
0%
2017 Luxury (stock Crawl)- Added MTS
7.32%
2018 Base - Added Crawl
0%
2018 Base - Added Crawl/MTS
0.81%
2018 Premium - Added Crawl
0.81%
2018 Premium - Added Crawl/MTS
4.07%
2018 Luxury - Added Crawl
0%
2018 Luxury - Added Crawl/MTS
0.81%
2018 Luxury (stock Crawl)- Added MTS
0.81%
2019 Base - Added Crawl
0%
2019 Base - Added Crawl/MTS
0.81%
2019 Premium - Added Crawl
0%
2019 Premium - Added Crawl/MTS
4.88%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
2019 Luxury (stock Crawl)- Added MTS
2.44%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
Old 08-21-19, 02:23 PM
  #901
nebrou
nebrou's Avatar
Originally Posted by Acrad35751
First post... need the 070 switch and whole switch assembly is replaced
https://www.oemvehicleparts.com/oem-...tch-8497060070
Thanks. IS this the only thing needed for CC ?
Old 08-21-19, 03:12 PM
  #902
Acrad
Super Moderator
Acrad's Avatar
Received 3,638 Likes on 2,383 Posts
For Crawl Control hardware you just need the switch and then need to do the ZPC (software piece) with either Techstream or paper clip via OBD.
https://www.clublexus.com/forums/att...caibration.pdf
Multi Terrain Select is another module. That one is plug and play.
Old 08-30-19, 04:51 PM
  #903
Acrad
Super Moderator
Acrad's Avatar
We won't know until someone gets their hand on a 2020 how easy it will be to convert (non-equipped) but changes with MTS for 2020 from what I have seen in the owner's manual are as follows:
- 6 modes instead of previous 4.
A "Rock and Dirt" and "MTS AUTO" mode added
- No longer possible to run "Mud & Sand" in 4H
Crawl operation is basically the same.
ltsr (08-30-19)
Old 08-31-19, 07:31 AM
  #904
CV460
CV460's Avatar
Default 2016 gx460. MTS
Hi Guys new to the Thread I have a 2016 gx460 premium and want to to get the MTS only what do I need and is it plug and play? If you have part number that would be great.also when installing do I just turn truck off or disconnect battery.
thanks guys I know I got on this one late can’t believe I miss this!!! If it’s plug and play I’m ordering part today😁
Old 08-31-19, 07:42 AM
  #905
Acrad
Super Moderator
Acrad's Avatar
`14 use the 040 and it really is plug and play. I just turned vehicle off for this mod. MTS will be there when you turn vehicle back on.
PN: 859A1-60040
Old 08-31-19, 08:39 AM
  #906
CV460
CV460's Avatar
Default 2016 gx460
So that 40 module will work with a 2016 correct ?
Old 08-31-19, 08:43 AM
  #907
Acrad
Super Moderator
Acrad's Avatar
Correct.
All 14-19 models
A different module version is used for 10-13 models
Old 09-01-19, 08:48 AM
  #908
CV460
CV460's Avatar
Default 2016 premium gx460
I pulled the trigger yesterday and ordered 859A1-60040 so can have the MTS option I don’t need to purchase the control switch’s for the CC to have the MTS to work? All I have on mine is the DAC and 4L switch’s
thanks🙏
Old 09-01-19, 08:59 AM
  #909
Acrad
Super Moderator
Acrad's Avatar
No additional hardware needed for MTS other than the 040. You toggle to it with existing switchgear on right side of steering wheel.
Old 09-01-19, 12:04 PM
  #910
shmelvin1
shmelvin1's Avatar
Is there anyone in the Seattle area, who has added the new switches and done the reprograming would be willing to help me? Practice makes perfect and honestly I'm a bit nervous poking and hoping around internal electronics.
Old 09-06-19, 07:12 AM
  #911
kingtux
kingtux's Avatar
This hasn't been installed and tested yet but looks like the 090 is that unicorn Crawl switch for non-AVS/RAHC models. Here are a few pictures kindly shared by GXOR member who purchased the switch. I will begin updating Wiki and this thread. No confirmed installs yet but really no reason to believe this won't retrofit like the 070.
$269.67
https://www.oemvehicleparts.com/oem-...tch-8497060090
PN: 84970-60090
Any update if this switch works?
Old 09-06-19, 07:16 AM
  #912
Acrad
Super Moderator
Acrad's Avatar
Still waiting to hear someone report back. I have heard of 3 or so that have ordered it. Hopefully we will hear something soon.
mattparts (09-06-19)
Old 09-06-19, 07:22 AM
  #913
kingtux
kingtux's Avatar
Thanks bud! I'm tempted to pull the trigger on this switch
Old 09-06-19, 04:54 PM
  #914
mattparts
mattparts's Avatar
We shipped out 5 more today that just came in this morning. Thats a total of 7 ordered so far
Acrad (09-06-19)
Old 09-06-19, 05:30 PM
  #915
shmelvin1
shmelvin1's Avatar
Anyone interested in a DRIVING SUPPORT SWITCH CONTROL COMPUTER 859A1-60040 there is one left on Amazon for $149
Amazon Amazon
I was a little skeptical because it was so cheap, but mine just arrived in a Toyota bubble wrap bag, it appears to be brand new not a scratch on it and you can see it was never installed as there are zero marks around the hole were the nut/bolt attaches.
Quick Reply: MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
