View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2010 - Base - Added Crawl/MTS
0.81%
2010 - Premium - Added Crawl
0.81%
2010 - Premium - Added Crawl/MTS
1.63%
2010 - Premium (stock Crawl) - Added MTS
3.25%
2011 - Base - Added Crawl
0%
2011 - Base - Added Crawl/MTS
4.07%
2011 - Premium - Added Crawl
1.63%
2011 - Premium - Added Crawl/MTS
2.44%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Base - Added Crawl/MTS
2.44%
2012 - Premium - Added Crawl
0.81%
2012 - Premium - Added Crawl/MTS
4.88%
2012 - Premium (stock Crawl) - Added MTS
0%
2013 - Base - Added Crawl
0.81%
2013 - Base - Added Crawl/MTS
4.07%
2013 - Premium - Added Crawl
0.81%
2013 - Premium - Added Crawl/MTS
5.69%
2013 - Premium (stock Crawl) - Added MTS
1.63%
2014 Base - Added Crawl
0%
2014 Base - Added Crawl/MTS
3.25%
2014 Premium - Added Crawl
0.81%
2014 Premium - Added Crawl/MTS
4.07%
2014 Luxury - Added Crawl
0.81%
2014 Luxury - Added Crawl/MTS
3.25%
2014 Luxury (stock Crawl)- Added MTS
4.88%
2015 Base - Added Crawl
0%
2015 Base - Added Crawl/MTS
2.44%
2015 Premium - Added Crawl
0%
2015 Premium - Added Crawl/MTS
1.63%
2015 Luxury - Added Crawl
0.81%
2015 Luxury - Added Crawl/MTS
0.81%
2015 Luxury (stock Crawl)- Added MTS
0.81%
2016 Base - Added Crawl
0%
2016 Base - Added Crawl/MTS
4.07%
2016 Premium - Added Crawl
0%
2016 Premium - Added Crawl/MTS
4.07%
2016 Luxury - Added Crawl
1.63%
2016 Luxury - Added Crawl/MTS
0.81%
2016 Luxury (stock Crawl)- Added MTS
0.81%
2017 Base - Added Crawl
0%
2017 Base - Added Crawl/MTS
3.25%
2017 Premium - Added Crawl
0%
2017 Premium - Added Crawl/MTS
2.44%
2017 Luxury - Added Crawl
0.81%
2017 Luxury - Added Crawl/MTS
0%
2017 Luxury (stock Crawl)- Added MTS
7.32%
2018 Base - Added Crawl
0%
2018 Base - Added Crawl/MTS
0.81%
2018 Premium - Added Crawl
0.81%
2018 Premium - Added Crawl/MTS
4.07%
2018 Luxury - Added Crawl
0%
2018 Luxury - Added Crawl/MTS
0.81%
2018 Luxury (stock Crawl)- Added MTS
0.81%
2019 Base - Added Crawl
0%
2019 Base - Added Crawl/MTS
0.81%
2019 Premium - Added Crawl
0%
2019 Premium - Added Crawl/MTS
4.88%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
2019 Luxury (stock Crawl)- Added MTS
2.44%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
Old 09-17-19, 02:33 PM
  #931
Acrad
Super Moderator
Acrad's Avatar
Received 3,638 Likes on 2,383 Posts
You will have to work around the internals of the switch.
Here is an example of my stock 080 from my '12 Premium
Old 09-17-19, 06:31 PM
  #932
shmelvin1
shmelvin1's Avatar
Mine has blank switch plates with nothing underneath but bits of plastic (all above the circuit board) I think it is doable?
Old 09-18-19, 06:25 AM
  #933
Chasin
Chasin's Avatar
How much space is underneath the blank switches?
Old 09-18-19, 02:11 PM
  #934
Acrad
Super Moderator
Acrad's Avatar
I'm not sure I have seen the internals of the stock 100 switch (non-crawl models without AVS/RAHC )
Old 09-18-19, 05:06 PM
  #935
shmelvin1
shmelvin1's Avatar
undo 3 screws and the entire top of the switch (cover) lifts off revealing the space below the blanks. You will need to cut away the plastic superstructure to figure a way to install an auxiliary switch
Old 09-18-19, 06:36 PM
  #936
Huskers
Huskers's Avatar
So I am a little concerned about going with to 090 switch (although it is what I would prefer and not having useless switches) vs doing the 070. I have a 012 Premium that I have put a 2" lift on and deleted the airbags and suspension...and currently no lights on dash. I don't want to introduce a new circuit that might cause Xmass lights on the dash. Silly concern? or just stick to the 070? Also the ZPC doesn't seem horrible, but I need to get the air intake taken care of so I wonder if anyone has done ZPC with Kuni Lexus of Denver? thanks in advance!
Old 09-19-19, 02:58 PM
  #937
Acrad
Super Moderator
Acrad's Avatar
Anyone up to disassembling their 2 toggle 100 switch and posting pics for comparison to the 80 switch I did a few posts above?
I'm curious how similar/dissimilar the circuit boards are.
Thanks!
Old 09-19-19, 04:44 PM
  #938
xplorr
xplorr's Avatar
Here is the 84970-60090, I haven't had a chance to install it yet:
The following 2 users liked this post by xplorr:
Acrad (09-19-19), ObsidianBl (09-28-19)
Old 09-19-19, 05:06 PM
  #939
shmelvin1
shmelvin1's Avatar
I was just going to post the same pics...….As you can see there is plenty of room to add an extra switch, the hard part will be making it look "factory" or at least professional?
It would be really cool if you could convert the small blank switch into a push switch like OEM
Old 09-21-19, 04:55 PM
  #940
shmelvin1
shmelvin1's Avatar
Default Need help with Zero point Calibration
I installed the crawl switch on a 2016 and attempted the OBD jumper calibration and it failed. I did everything exactly in the video but never got the fast flashing lights and now my slip sensor light wont go out...Can anyone advise me on what to do?
Nusbaum (01-10-21)
Old 09-21-19, 05:25 PM
  #941
tecman
tecman's Avatar
What video are you referring to please.
Old 09-21-19, 05:27 PM
  #942
shmelvin1
shmelvin1's Avatar
Old 09-21-19, 05:54 PM
  #943
Acrad
Super Moderator
Acrad's Avatar
Fitment on parts sites shows 10-19
https://parts.lexus.com/p/Lexus__/SW...497060090.html
I've never personally done the OBD method but used Techstream. Are you pushing the ON/OFF button before turning off vehicle? I wonder if you have have a defective switch?
EDIT: Are you on a flat level surface with wheels straight as well?
Old 09-21-19, 06:02 PM
  #944
shmelvin1
shmelvin1's Avatar
The switch is brand new, and the 4 low works fine, and yes I am pushing the on off button after the sequence, but as I never got the fast flashing after turning back on after turning the OBD jumper between 4 & 12 on and off 4 times It seems unlikely it is the switch?
I will have to make an appointment at the local Toyota specialist ASAP as they already told me they can do it for 1 hour labor, I'm sure it will take less than 5 minutes so I was just being cheap and it bit me in the ****...….
Old 09-21-19, 06:09 PM
  #945
Acrad
Super Moderator
Acrad's Avatar
Sorry to hear you are having issue...please keep us posted
EDIT: Do you have an OBD setup like OBD Fusion/Link? You can pull codes to see why light is on. I suspect it reset the calibration but isn't calibrating the new one for some reason.
Quick Reply: MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
