View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2010 - Base - Added Crawl/MTS
0.80%
2010 - Premium - Added Crawl
0.80%
2010 - Premium - Added Crawl/MTS
1.60%
2010 - Premium (stock Crawl) - Added MTS
3.20%
2011 - Base - Added Crawl
0%
2011 - Base - Added Crawl/MTS
4.00%
2011 - Premium - Added Crawl
1.60%
2011 - Premium - Added Crawl/MTS
2.40%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Base - Added Crawl/MTS
2.40%
2012 - Premium - Added Crawl
0.80%
2012 - Premium - Added Crawl/MTS
4.80%
2012 - Premium (stock Crawl) - Added MTS
0%
2013 - Base - Added Crawl
0.80%
2013 - Base - Added Crawl/MTS
4.80%
2013 - Premium - Added Crawl
0.80%
2013 - Premium - Added Crawl/MTS
5.60%
2013 - Premium (stock Crawl) - Added MTS
1.60%
2014 Base - Added Crawl
0%
2014 Base - Added Crawl/MTS
3.20%
2014 Premium - Added Crawl
0.80%
2014 Premium - Added Crawl/MTS
4.00%
2014 Luxury - Added Crawl
0.80%
2014 Luxury - Added Crawl/MTS
3.20%
2014 Luxury (stock Crawl)- Added MTS
4.80%
2015 Base - Added Crawl
0%
2015 Base - Added Crawl/MTS
2.40%
2015 Premium - Added Crawl
0%
2015 Premium - Added Crawl/MTS
1.60%
2015 Luxury - Added Crawl
0.80%
2015 Luxury - Added Crawl/MTS
0.80%
2015 Luxury (stock Crawl)- Added MTS
0.80%
2016 Base - Added Crawl
0%
2016 Base - Added Crawl/MTS
4.00%
2016 Premium - Added Crawl
0%
2016 Premium - Added Crawl/MTS
4.00%
2016 Luxury - Added Crawl
1.60%
2016 Luxury - Added Crawl/MTS
0.80%
2016 Luxury (stock Crawl)- Added MTS
0.80%
2017 Base - Added Crawl
0%
2017 Base - Added Crawl/MTS
3.20%
2017 Premium - Added Crawl
0%
2017 Premium - Added Crawl/MTS
2.40%
2017 Luxury - Added Crawl
0.80%
2017 Luxury - Added Crawl/MTS
0%
2017 Luxury (stock Crawl)- Added MTS
7.20%
2018 Base - Added Crawl
0%
2018 Base - Added Crawl/MTS
0.80%
2018 Premium - Added Crawl
0.80%
2018 Premium - Added Crawl/MTS
4.00%
2018 Luxury - Added Crawl
0%
2018 Luxury - Added Crawl/MTS
0.80%
2018 Luxury (stock Crawl)- Added MTS
0.80%
2019 Base - Added Crawl
0%
2019 Base - Added Crawl/MTS
0.80%
2019 Premium - Added Crawl
0%
2019 Premium - Added Crawl/MTS
5.60%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
2019 Luxury (stock Crawl)- Added MTS
2.40%
Voters: 125. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
Old 10-02-19, 07:14 PM
  #961
thisxguy
thisxguy's Avatar
Originally Posted by Acrad
IMO: It shouldn't be a problem to reverse mods. Not sure dealer would even notice the installation of these OEM parts and it might even be a selling point for the second owner.
Thats true. But if I was trading it in I’d prob pull the modules to sell to another buyer if it’s fairly simple
Acrad (10-02-19)
Old 10-02-19, 07:21 PM
  #962
Acrad
Super Moderator
Acrad's Avatar
Received 3,654 Likes on 2,392 Posts
Just swap back stock ECU that enables MTS and DAC switch followed by another ZPC procedure and you will be back to stock
KJ6IRM (10-02-19)
Old 10-04-19, 09:39 AM
  #963
thisxguy
thisxguy's Avatar
That's what I was thinking. Okay I'll probably be doing this mod in the next few months on my 2019 Premium...depending on how time is with the incoming newborn.
Old 10-11-19, 02:41 PM
  #964
cancruiser
cancruiser's Avatar
Originally Posted by ObsidianBl
2014-17 owners that added the -40 module for MTS.... Did you also “unlock” the dynamic lines on the rear view camera when in reverse?
Went through the entire thread (all 58 pages of it ) and it seems no reports to answer this question?
Old 10-11-19, 02:46 PM
  #965
shmelvin1
shmelvin1's Avatar
What does that mean....“unlock” the dynamic lines on the rear view camera
Old 10-11-19, 02:49 PM
  #966
cancruiser
cancruiser's Avatar
The two lines on the rear view camera display which move as you turn the steering wheel
Old 10-11-19, 02:51 PM
  #967
shmelvin1
shmelvin1's Avatar
Good question, I haven't noticed if mine move or not...If they don't I would also like to know how?
Old 10-11-19, 05:28 PM
  #968
Acrad
Super Moderator
Acrad's Avatar
No....this mod doesn’t do dynamic lines. It was just speculation at the time,
Old 10-18-19, 01:27 PM
  #969
Acrad
Super Moderator
Acrad's Avatar
While putting in my VAIS bypass a few weeks back I lost one of the clips at starred spots on the following trim piece. This trim is also removed to install the crawl switch.
EDIT: Correction- install of MTS...not required for crawl switch
To keep this from happening again or occurring just put a small piece of black electrical tape on them before putting them back into place. This will prevent them from potentially dropping into the console. Trim piece will still fasten nicely and nothing can be seen.
PN: 90468-04157 - Finish Plate Retainer
$1.18 each
ltsr (10-18-19)
Old 10-18-19, 07:00 PM
  #970
immykins
immykins's Avatar
Acrad - I'm literally just pulling my glove box out now to do the computer and figure I'll change the center switches at the same time. Is there a guide somewhere for that?
Old 10-18-19, 07:14 PM
  #971
ObsidianBl
ObsidianBl's Avatar
Watch @techman video on removing the center area.
@Acrad posted it along with the crawl control zero point calibration by @coinball
MTS can be swapped out by following the remote start install.
https://www.clublexus.com/forums/att...t-ac6a39f2.pdf
Acrad (10-19-19)
Old 10-18-19, 08:20 PM
  #972
bbqsoup
bbqsoup's Avatar
If you have glass break sensor, it’s good to adjust its sensitivity while you’re doing the MTS module as well.
Acrad (10-19-19)
Old 10-19-19, 06:07 AM
  #973
Acrad
Super Moderator
Acrad's Avatar
Also a good time to install Remote Start (RES) and GBS if not stock equipped.
Old 10-19-19, 08:19 AM
  #974
nebrou
nebrou's Avatar
How much does remote start part cost?
Old 10-26-19, 09:59 AM
  #975
DDahl
DDahl's Avatar
The attachment contains two function tables from the Lexus TechDoc that defines what braking functions are active when. The first table covers GXes with only Crawl control. The second table covers Gxes with both MTS and Crawl control.
Notice that if you have both installed MTS must be active for A-TRAC to function. Thus it appears that the MTS level selected sets the level of A_TRAC applied during Crawl. This is consistent with my observations and also with the 2020 GX
owner's manual discussion of MTS and Crawl. In the 2020 GX they have 5 levels of MTS and 5 Levels of Crawl. When Crawl is selected the crawl speed is used to determine which MTS level to automatically use. With our installations it appears
that we must set the MTS level first (Crawl Off) and then turn crawl on. At least that's how it appears to work for me.
Dave
Models with CRAWL.pdf
The following 2 users liked this post by DDahl:
ltsr (10-26-19), Mojlnir (10-26-19)
Quick Reply: MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
