View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2011 - Base - Added Crawl
0%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Premium (stock Crawl) - Added MTS
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 125. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#991
Super Moderator
Super Moderator
A few pages of FSM I guess I passed over while looking in the Brake chapter this afternoon.
hzhao (11-06-19)
#993
Super Moderator
I was looking parts up for another member the other day.
If you lose any of the white or pink clips on those console side trim pieces here are the part numbers:
White clips - PN: 9046710201
Pink Clips - PN: 9046712080
While putting in my VAIS bypass a few weeks back I lost one of the clips at starred spots on the following trim piece. This trim is also removed to install the crawl switch.
EDIT: Correction- install of MTS...not required for crawl switch
To keep this from happening again or occurring just put a small piece of black electrical tape on them before putting them back into place. This will prevent them from potentially dropping into the console. Trim piece will still fasten nicely and nothing can be seen.
PN: 90468-04157 - Finish Plate Retainer
$1.18 each
$1.18 each
#994
So much simpler and cheaper on the Prado for this switch
Might be a retrofit option if someone wanted to mount some other place and run some wires.
or find some bracket to mount lower on the dash like a brake controller ....lots of different aesthetic and functional scenarios
It is ---> 84970-60060
https://carmarka.com/en/toyota-switc...wl-84970-60060
https://www.megazip.net/zapchasti-dl...-relay-7456345
This might be extremely relevant again.
John00 (11-17-19)
#995
Quick question (sorry if i missed it in this thread, its gotten pretty long). I installed the CC 070 module on my premium 2012 (already did the MTS). After installing, nothing is showing up...do you have to do the ZPC before anything shows up in center dash? Right now I can't find anything different than prior to the install. BTW, the front screw nearest to the driver was a bear to deal with.
thanks in advance.
thanks in advance.
#996
Super Moderator
Correct. You have to do the ZPC for it to work. Are you doing it with Techstream or the wire method?
#997
I need to get the secondary intake done on recall (along with transmission oil change) and I was going to have the dealer do it when it was in. If not, I will try paper clip...if that fails try to hook up with someone in Denver for techstream.
#998
So Acrad I figured I would move our talk to this section. Below are the pics I took.I hope we can figure it out
#999
Super Moderator
Can you take pictures of that 85940-60120 module wiring connector so we can see the pin-out and wire colors on the connector?
#1001
need to add CC during cal. this isnt in the official docs because its already done at the factory when you do have CC>
right before exit push the CC on/onn button. you get a quick flash of the icon light. this is when using TS
then you exit.
then you exit.
thanks in advance.
thanks in advance.
Huskers (11-17-19)
#1002
Super Moderator
Super Moderator
g60man: When we search out that module (85940-60120) we find a 2018 Prado that is being parted out. It makes me think not related to MTS. Wondering if they moved the MTS logic to the 4WD computer further to the right under front passenger dash?
http://saggrendaext.azurewebsites.ne...r=276527&f=369
Looking at pics one can see this Prado is equipped with MTS and Crawl from those center controls. IIRC... some '18 Prado tech is basically what is now being used on '20... like new terrain monitor...etc.
bbqsoup (11-17-19)
#1004
Wow. Center and also rear diff lock too? This is Land Cruiser kind of options.
#1005
My thoughts also
my thoughts also
