View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
0%
2011 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar1-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar1.gif)
![](https://www.clublexus.com/forums/images/polls/bar1-r.gif)
0%
2011 - Premium (stock Crawl) - Added MTS
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
0%
2012 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar6-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar6.gif)
![](https://www.clublexus.com/forums/images/polls/bar6-r.gif)
0%
2012 - Premium (stock Crawl) - Added MTS
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#91
This is really cool!!! Glad you were able to get it done...AWESOME!
#92
Super Moderator
Pretty stoked right now!!! The MTS piece hasn't been proven yet but as-is getting CC on a GX should be $250-$300 or a lucky find in a junk yard. There is a used $200 unit on one of those wrecking yards I previously posted.
I'm curious if this mod can be literally done on any non-CC GX 460? Might start seeing a lot more 4 switch GXs out there that don't actually have Adaptive Variable Suspension (AVS) and Rear Adjustable Height Control (RAHC).
#94
Super Moderator
Super Moderator
Hopefully as plug and play for everyone else. This can be done without Techstream but I used TS in this instance. The calibration instructions earlier in thread allow you to utilize a shorting of two connectors on the OBD port.
This was cheapest place I found for console switch
https://www.megazip.net/zapchasti-dl...?q=84970-60070
They always have a 10% coupon up there it seems. Out the door including the shipping it was $272.14 for this console switch PN: 84970-60070
There is always a chance one could make their own custom switches a well. Some on linked Prado RU forums had done that.
bbqsoup (02-23-18)
#96
If you were closer, I'd definitely get you some beer and dungeness crabs just to check it out LOL.
So these parts that need?
Driving Support Computer PN: 859A1-60020
Console Switch PN: 84970-60070
Acrad (02-23-18)
#97
Super Moderator
Yeah.... those are the parts. I'm fairly confident on the Driving Support Computer for MTS but still need to prove on that one. The 020 model is also only for the '10-'13. There is a different model for the '14+. There are a number of model numbers. That being said they should all be using the same Console Switch.
bbqsoup (02-23-18)
#98
So switching out the DSC under the dash/glovebox is fairly simple?
I can't wait to see you test this in some real terrains.
Btw, how did you get the Japan site to ship to US? Just input the US address and it will calculate the shipping fee? Looks like the price is $137 now.
#99
Super Moderator
I haven't gotten to the full step of removing the glove box but I think I was only a couple bolts from pulling out glove box piece while I was trying to take pictures of the DSC wiring the other day. I'll note more on this as I swap this unit out for the MTS test. This may be sooner than later. :-)
I told Japan site to ship the cheapest and they came back with Japan Parcel Post IIRC... it was under $7 to ship to me in WA state. It came in to LA and then was transferred to USPS. The console switch will arrive USPS as well.
#100
Super Moderator
If one just wanted CC this mod could be reverted back to stock fairly quickly if one desired. Put back in stock switch and re-run the calibration routine for DAC detection.
A few notes on the console switch replacement
• I found easier to remove the side padded trim along side the side of the console. This may not be needed but found it easier in reinstalling the entire console of the tecman video
• Used a bungee cord to hold up the console so I didn't have to completely disconnect everything on the center console area. The forward area of the console area is also held in by clips so you can pull toward you and tip up further.
• Connector on console switch easily releases
• The two items that connect to the bottom of the console switch/ one it's own wire connector and not sure offhand what the other box is for / these will release if you use some long needle nose pliers. This will become evidient when you are down there disconnecting the stock switch.
• Console switch is held in by 4 screws. I found getting the rear inner screw in easier by taking a piece of black electrical tape and taping to end of screw driver. That is probably the hardest area to get screw in. Ironically though it has an extra tab that supports console switch in this area so it might not be necessary to put this screw in . It felt fairly solid with the three. I got the 4th screw back in with tape tip though.
The following 5 users liked this post by Acrad:
#101
bbqsoup (02-23-18)
#102
Super Moderator
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/836x1059/screen_shot_2018_02_23_at_3_43_30_pm_e94859eae9a39bfc96c4dea569102a5a2bc14356.png)
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/845x938/screen_shot_2018_02_23_at_3_43_54_pm_7d23da62b758aa71c90ee17521f79ebd5a5ab7d9.png)
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/814x894/screen_shot_2018_02_23_at_3_44_06_pm_e441ad4af7b60d955a3fdd0c39a13395d025f8cd.png)
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/849x1000/screen_shot_2018_02_23_at_3_44_18_pm_a17690c9c84106e90f0b80bc1351d310a7dab042.png)
#103
I haven’t chimed in because I have no need for this but I will chime in to thank you for this Excellent mod Acrad, thanks for your contributions here ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Acrad (02-23-18)
#104
Super Moderator
Hopefully I don't unravel the good feeling today. I'm gonna put in the uprev Driver Support Computer tomorrow. Fingers crossed MTS shows up.
#105
I was getting email updates throughout the afternoon. Part 1/2 is complete. Congrats on the success!
Do you know if the two suspension switches can be removed or modified to work with something else? It doesn’t look like it since it’s all one control board and one connector.
