View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2011 - Base - Added Crawl
0%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Premium (stock Crawl) - Added MTS
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 125. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
The following 2 users liked this post by BPGX460:
Acrad (11-09-20),
SamLexRXGX (11-09-20)
#1112
#1113
Super Moderator
^ that didn't look like much to get stuck in, even with those tires being pretty coated. Guessing it is a lot muddier than what it looks to be.
I've been waiting for a good snow dump here in CO to mess around with it.
#1115
Super Moderator
Not sure if that is the case here but one has to keep in mind that for best results with ATRAC you want to keep RPM below 2500RPM.
#1116
Combo Switch for vehicles without precrash
I see most references to the use of the 60070 combo switch for 4 switch replacement with gx460’s with ride control. Now I’m seeing a new number 60080 for gx460’s without precrash. There is no discussion about this difference, so will the 60070 work with both, just not be affected by precrash software or is the 60080 vital to units without precrash?
#1117
Super Moderator
You want 070 if you have AVS/RAHC and 090 if you don't have that or removed AVS/RAHC (Rear bags and adjustable shocks). Pre-crash is not affected.
60070
60080
60090
60100
60070
60080
60090
60100
#1118
Super Moderator
If someone has a 2020+ Luxury model you can help the effort to bring Crawl/MTS to non-equipped 20+ models by posting some pictures of the wiring connected to your skid control ECU. At this time it would seem wiring is missing from a Base/Premium. We do not know if Luxury lacks the wiring.
••It would be great to see wiring of a Luxury with Off-Road-Package as well.
2020 Base/Premium models seem to lack some of the wiring.
IH8Mud Forum posting
#1119
Super Moderator
I've looked into this potential "090" type crawl switch for 20+ and I suspect this might be a custom switch that was created for Al-Futtaim motors in UAE. I've seen in the past where they have sent out LCs/LX 570s for custom work.
https://www.lexus.ae/new-cars/gx460/
This specific version isn't sold at any other Lexus dealers in the area.
They have a pricing/spec sheet here but this appears to be somewhat of a custom creation. Example shows model lacking RAHC/AVS and close up shots appear show 3rd party aftermarket gear including some yellow coils.
https://nd-mediagallery2-public-prod...exus_gx460.pdf
Again lots of speculation hear but that top part of switch is of a different design that any other two switch before it.
This solid design on top is odd considering a standard '20+ DAC switch looks like this. Thinking 3D printed.
I reached out to Partsouq with this info but unless I can come up with a VIN from these example vehicles they can't help me confirm or deny these are custom switches.
https://www.dubicars.com/2020-lexus-...ct-319617.html
https://www.dubicars.com/2020-lexus-...68-322957.html
#1120
I have 2013 gx 460 premium CC and MTS for sale
I recently installed MTS and CC on my 2013 lexus GX 460. Unfortunately, I met with an accidents and wrecked my car. I was able to swap out the custom parts and mods I did to my vehicle witb originals. So was able to retain 20inch wheels and tires WeatherTech floor liners and MTS and CC modules. Please check out club lexus market place, i have listed the parts for sale
#1121
Super Moderator
A GXOR member passed these pics onto me.
Here is an example of a '20 Luxury w/off-road package.
We still need to see if '20+ Luxury without off-road package has this wiring or if absent like base & premium
hzhao (12-27-20)
Acrad (12-28-20)
#1123
Super Moderator
Thanks!
It is that ECU that is attached the brake master cylinder. It is often referred to as the skid control ECU as well. I'm not sure how easy that connector is to remove.
#1124
Ok.. I didn't spend much time, since I'm still technically "working", so I didn't unplugged it because I didn't want to unplug the battery (not sure if it's needed). Hopefully, this helps. If it doesn't, then I could spend a bit more time removing it and unplugging the battery.
I know some of the pics are a bit blurry but hopefully, the video and pics get us what we're looking for.
#1125
Super Moderator
Thank you!
It does look like the non off-road Luxury has the wiring.
Your block has the wiring that is missing from the base/premium
Base Premium with missing wires
Luxury w/off-road
Luxury w/off-road
