View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
0%
2011 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar1-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar1.gif)
![](https://www.clublexus.com/forums/images/polls/bar1-r.gif)
0%
2011 - Premium (stock Crawl) - Added MTS
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
0%
2012 - Base - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar6-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar6.gif)
![](https://www.clublexus.com/forums/images/polls/bar6-r.gif)
0%
2012 - Premium (stock Crawl) - Added MTS
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#106
Super Moderator
Possible but not sure.. looking at switches it does appear it comes apart fairly easily.
Hypothetical...One might be able to remove the suspension switches and then overlay the stock top piece that has the DAC markings on it.
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/360x480/80_img_7901_54c130867cc584cc67fa353ddc66871d0928bc4b_1c4da57f36323e73011d01211e673b5063b92482.jpg)
#107
Super Moderator
You basically have three switch types
'10-'13 Base & '14+ Base/Premium
https://www.mylparts.com/oem-parts/l...tch-8497060090
'10-'13 Premium and '14+ Luxury without Driver Support Package
https://www.mylparts.com/oem-parts/l...tch-8497060080
'10-13 Premium with crawl / '14+ Luxury with Driver Support
https://www.mylparts.com/oem-parts/l...tch-8497060070
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/640x480/gx_standard_model_buttons_517089fe2a378ef33a04d5815666011cb958a861.jpg)
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/480x640/80_img_7906_7f62bf2d0c0a287d80e7ce0e0f10ce73740897ce_8278677d5cffdee12e00d4ec6cfa8d84f9ffb7f1.jpg)
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/360x480/80_img_7914_913589fda74fe0048c0c3a50d3c2a5a069fb2540_62f08e3b66d61d585ff0808d41cea6067fa7f767.jpg)
#109
Super Moderator
Another option I previously posted. You will pay at least $100 more if you buy from US dealer.
This place actually has the 84970-60070 @ $190.70
With S/H they emailed me back $253.70
https://carmarka.com/en/search/index?q=84970-60070
#110
Just to be clear since I have a 2016 premium w/o driver support....to get crawl control and MTS (if it works) all I would need is the following. https://www.mylparts.com/oem-parts/l...tch-8497060090
#111
#112
Super Moderator
I hope to know more about the MTS today.
#113
Based on Acrad's experiment, Part# 84970-60070 (console switch) is all needed to get Crawl Control function to work. Part# 859A1-600xx is needed to gain MTS function (if works). Where xx is determined by different model years. For 2010-2013, part # is 859A1-60020, for 2014+, part # 859A1-60040, etc.
Thanks for the response.
#114
Super Moderator
Well after a little painful extraction to area of glove box...... plugged in the 020 module and this is what we got---->
I need to put together and road test but I'd say this is encouraging. :-)
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/640x480/img_7922_80a7f4f4d12f75a35c1a2c3682d7e63736a1aad3.jpg)
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/640x480/img_7926_be0cae8a64630f0d8bbcb4439cd368c0cbe4964e.jpg)
#115
Super Moderator
Took it out and seems to work. MTS indicator lights up on dashboard when it is live. This is used separately from Crawl Control. It even shows camera view options in the MTS settings. Looks like if I wanted to add the front and side camera I would be set to do so.
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/640x480/img_7934_24ac952a0e18e0238b5db1e9f51080d604963548.jpg)
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/640x480/img_7935_061e0fb89052fbe25d3dd67c2a1b8ca5fc737d7c.jpg)
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/417x355/screen_shot_2018_02_24_at_4_00_49_pm_d23302f70492c31029f4e758f7da9e777ac7d858.jpg)
#118
Super Moderator
Yeah pretty excited to get these options onboard. It will be a unique US optioned vehicle for a short period anyway. :-)
#119
Super Moderator
Any Canadians here with a GX with Driver Support Package?
It would be interesting to get a more definitive part number for the '14+ models on the Driver Support Computer
#120
Ok thanks I was confused since there were links to console switches for GX460 without driver support, we all need the same console part Part# 84970-60070 if MTS is wanted? And based on year the drive control module.
