View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2011 - Base - Added Crawl
0%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Premium (stock Crawl) - Added MTS
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#1186
Super Moderator
I was chatting with Matt@OEM about these 10-19 parts and he said Japan inventory on these parts ran dry a month ago and now North America Toyota/Lexus parts chains are starting to tighten up as well and even dealerships are beginning to struggle getting these parts. Availability may be sparse for a while. If you are thinking about picking these up and can find availability anywhere you may want to act on it. Not sure when backlog will be caught up.
#1187
Super Moderator
I know '20+ w/MTS & Crawl adds Auto and Rock & Dirt mode but curious to hear from '20+ equipped 460 owners if they are seeing what is reported here for the Tacoma.
https://tfltruck.com/2020/12/ask-tfl...hats-going-on/
#1188
Super Moderator
An IH8Mud member added Turn Assist Control, MTS and 5 speed crawl to '10 LX 570 here
'08-'11 LX/LC just had 3 speed crawl
The network gateway ECU was the final piece of that puzzle. Something to consider for '20+ conversions if skid control ECU turns out to be a bust. The fact this version
8911147080
also works with 2019 models makes me suspect it won't be relevant for '20+ conversions. Perhaps in '19 for the updated 4G Enform?
https://parts.lexus.com/p/Lexus_2020...911147080.html
8911147080
#1190
Super Moderator
Without additional buttons from mod below it would be single speed only with a repurposed DAC switch.
https://www.clublexus.com/forums/gx-...-switches.html
#1191
That's what I thought, but looking at Jackets video of him rolling into his driveway, if you look at when he first activates CC, it looked like it changed speeds from the second position (from the bottom) to the lowest position shown on his dash. I was thinking he changed it.
Since I have the premium version, I wonder if I could use the height control for changing CC speeds? I'll have to check to see if they are momentary switches or not. But they do toggle up AND down with default center.
But I'd like to continue this on MUD, since I'm not on here as often as MUD.
#1192
Super Moderator
It stays in last used speed and you do have to toggle up or down from every step.
The wiring diagrams for that full switch are here and on mud.... probably could repurpose the suspension switch..I just haven't heard anyone doing that yet.
#1194
Super Moderator
Finished zero point calibration. Crawl control registered successfully. I noticed after I installed the crawl control box and before zero calibration, vehicle air suspension seemed very rough. After zero point calibration and straight driving, got the suspension smooth. Dont know if its related. Any one who faced this issue?
#1197
Super Moderator
SamLexRXGX: I have not heard of that report before.
#1198
The status screen showed "Air suspension Test Mode" during the second step of the zero point calibration. I used the obd safety pin method. Looks like it calibrates airs suspension also. mine is luxury model with rear air suspension.
#1199
Super Moderator
Interesting...my '12 Premium has same suspension setup but I used Techstream as OBD method wasn't tested back then.
Any chance terminal 13 was grounded as well?
Crawl ZPC - https://www.clublexus.com/forums/att...alibration.pdf
RAHC test mode procedure in attached PDF.
#1200
