View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2011 - Base - Added Crawl
0%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Premium (stock Crawl) - Added MTS
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#1201
Super Moderator
IMO: I'd leave everything as-is and do nothing further.
You got it working
You got it working
SamLexRXGX (06-20-21)
#1202
Thanks Acrad and every one and this forum. There are tons of information.
#1203
How to check if the air suspension ecu and kdss are in proper working condition. I have techstream which i used for RES. looks like i still have rough ride after i drove on those speed breakers. As if no suspension. comfort or sport mode did not seem to change it.
#1204
Interesting...my '12 Premium has same suspension setup but I used Techstream as OBD method wasn't tested back then.
Any chance terminal 13 was grounded as well?
Crawl ZPC - https://www.clublexus.com/forums/att...alibration.pdf
RAHC test mode procedure in attached PDF.
Acrad, when using SST check wire mode, step e, 12,4 and 13, all have to be connected together, is that right.
This steps may be required since I did not do that absorber (comfort <->sport) switch moves. I am wondering thats why its rough.
I want to do either this way or techstream way. your inputs appreciated. Thank you.
#1205
Super Moderator
I only use Techstream for these kinds of tests. I haven't personally done any of the check mode tests with a wire myself. .. Can you visibly see rear of vehicle lower and raise stepping outside of vehicle while changing modes from a stop? Never seen documentation show 3 wires being connected at same time.. only two if suggested in documentation.
Have you tried forcing a high mode of suspension from a stop and let it drop at 18 or so MPH back to neutral position ? I've seen a few in past report a rough ride that was corrected for whatever reason doing this... it sounds like a height sensor recalibration to me but nothing in documentation to indicate that being an option.
#1207
Super Moderator
It would appear the documentation supports that but never heard of anyone needing to do this.
What speeds are you traveling? It sounds to me more an effect of potential bag pressure (possible addressed through High mode recalibration) than the AVS shocks not working which would trigger error on dash.
#1208
#1209
#1210
i believe step e can also be done by tech stream instead of the intelligent tester. i want to do on tech stream. Is it ok Acrad? Just wanted to see all these signals are coming.
#1211
Super Moderator
If codes aren't showing up with TS and/or OBD Link that more than likely confirms connectivity but that test would also appear to confirm connectivity.
A TS Active Test would confirm everything is working.
I've never done these tests myself.
SamLexRXGX (06-21-21)
#1212
If I am not mistaken, the air suspension in rear are mainly for height adjustment and auto leveling purpose, the ride quality in Luxury are controller by AVS, the active variable suspension, which is by controlling the shock damping rate to achieve softer, normal and spot riding. There is nothing to do with air suspension. BTW, I have not experienced any change with ride quality any settings after adding CC/MTS. I have used Techstream for ZPC.
#1213
May be i can verify the parameters in mx+ and if require i can re do using techstream. how to clear in techstream if in need. I felt this change after i switched to the crawl control module from existing one. Since I did in garage, i had to drive to a place where i can drive straight after the calibration.
#1214
i monitored damper step front left, right, rear left and right.
comfort mode almost 1 (all)
normal mode almost 7 or 8 (all)
sport mode 10 or 11 (all)
also noticed rear left height control sensor at 36.5 mm and rear right control sensor at -30 at N level.
At speed breaker front wheels adjusts faster and rear adjusts after it passes the breaker.
i tried this with right side wheels go on the speed breaker and left one on the normal surface, since the breaker was short length. so when it self corrects, it was harsh.
I read some where, when we clear ecu, AVS takes 100 miles to learn all the behavior. don't know its correct.
I expected its gradual correction, but felt harsh in correcting after one set of tires (right front and rear)go over the speed breaker.
#1215
