View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2011 - Base - Added Crawl
0%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Premium (stock Crawl) - Added MTS
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#1231
Super Moderator
Super Moderator
4R but MTS info
#1233
This is an interesting challenge.
I'll start checking my 21 premium and see its possible somehow and what would be the cost, don't expect quick progress as this is not an essential mod for me, yet, but one that I would like to add eventually
Will collect parts/plugs/cables as I find needed and if I succeed then I'll post the solution, if I fail I'll post the warnings
I'm terrible in documenting with photos, but will try to be more careful with this
Acrad (12-09-21)
#1234
Thats the spirit! I’m sure it’s possible - just gotta figure out the puzzle.
#1235
Super Moderator
Super Moderator
IIRC on those use some needle nose pliers and squeeze here and then pull from the top
phile (01-23-22)
#1238
thank you Acrad. That worked. I tried the paper clip recalibration method but I can’t seem to get cc to show up. Anything I’m missing?
I put the clips into the ports, turn on accessory mode. Lights in the dash are going crazy. I turn off. With clips still in the ports, I turn on accessory mode again. Lights are going crazy again. I hit the “off” button to turn cc on. But it doesnt light up on the dssh.
#1239
Super Moderator
Are you referring to the suspension OFF button or the Crawl ON/OFF button?
... need to make sure you are using the latter if that is the switch version you are using
#1240
thanks for the prompt reply! I was hitting the suspension button. No wonder cc wasn’t lighting up.
PS I attempted the MTS install but I found it harder than the CC. I have aborted & postponed it, I could not figure out that front panel under the glove box. He mentioned 3 10mm sockets but I only found 2.
#1241
Super Moderator
Are you referring to the knee airbag?
Take a look at this writeup
https://www.clublexus.com/forums/gx-...60-luxury.html
phile (01-23-22)
#1243
Super Moderator
It appears skid control ECU versions for '22 have remained the same as '20-'21
https://parts.lexus.com/p/Lexus__/SO...721760690.html
https://parts.lexus.com/p/Lexus__/SO...721760760.html
https://parts.lexus.com/Lexus_2022_GX-460.html
