View Poll Results: Crawl / MTS - model year/trim upgrade survey
2010 - Base - Added Crawl
0%
2011 - Base - Added Crawl
0%
2011 - Premium (stock Crawl) - Added MTS
0%
2012 - Base - Added Crawl
0%
2012 - Premium (stock Crawl) - Added MTS
0%
2014 Base - Added Crawl
0%
2015 Base - Added Crawl
0%
2015 Premium - Added Crawl
0%
2016 Base - Added Crawl
0%
2016 Premium - Added Crawl
0%
2017 Base - Added Crawl
0%
2017 Premium - Added Crawl
0%
2017 Luxury - Added Crawl/MTS
0%
2018 Base - Added Crawl
0%
2018 Luxury - Added Crawl
0%
2019 Base - Added Crawl
0%
2019 Premium - Added Crawl
0%
2019 Luxury - Added Crawl
0%
2019 Luxury - Added Crawl/MTS
0%
Voters: 123. You may not vote on this poll
MOD: Crawl Control (CC) and Multi Terrain Select (MTS)
#1247
Super Moderator
The Crawl switch will be obvious but make sure you aren't purchasing someone's old non-MTS switch either.
Remember last number need to be a 020 and not a 010 for a 2010-2013
#1248
bought my CC from ebay. Installed it using that youtube video as a guide, zero-calibrated it using the paper clip technique shown in the video, and it lights up the CC as expected on the screen. I have yet to actually test it on actual off road though.
Acrad (04-07-22)
#1249
Super Moderator
The cheapest 020 for 10-13 models is most likely this site at around $152 .
https://www.parts-sale.jp/TOYOTA%208...ch=859A1-60020
Shipping charges here
https://www.parts-sale.jp/delivery
The 020 was used on Prado in Japan so they can sell it... '14-'19 wasn't same unit and was not used on Prados so they cannot sell if not a JDM part.
#1250
Please correct me if I am wrong. PN: 84970-60070 CC for adjustable shocks/rear air bag models can be used on a non-AVS/RAHC model right? Just that top row switches are non-functional.
#1251
Super Moderator
It can definitely be used on those models.
You can also use 84970-60090 which doesn't have the upper toggle switches
psun786 (08-11-22)
#1252
could just use a simple switch and put it wherever you like. two wires are all that are really necessary if you want the most basic, least expensive.
#1253
Hazard light flashing continuously after MTS install
I installed MTS module and decided to reconnect car battery before put shifter & crawl control panel back. I will be doing more wiring works (360 camera, 2nd row USB and etc) so the shifter panel needs to be disconnected for now. The hazard light start flashing immediately after the battery is connected. It can't be turned off using the switch. The only way to disable it is disconnect the car battery.
Does anyone know if the hazard light is triggered by absent of shifter & crawl control panel? Or it indicates something else is not connected properly, like passenger airbag and sensor?
#1254
Super Moderator
I don't recall this symptom before regardless of mod. I'll look around.
#1255
does it do it with the switch disconnected? maybe theres a short in the switch or harness
#1256
Super Moderator
Just some reference pictures of the DAC/4WD controls from a '22-'23 model. If I see one with crawl/mts will post as well
The following 3 users liked this post by Acrad:
#1257
Whats happening with my CRAWL CONTROL?
I just bought my 2015 GX, and I wanted to test the four-wheel drive. I found an empty parking lot and put it in 4LO and drove it slowly. I then wanted to see what the CRAWL CONTROL could do so I engaged it, and as soon as I let off the brake pedal, it started stuttering badly. It sounded like the ABS trying to stop all the wheels at once.
Am I doing something wrong? No matter what speed I put the CRAWL CONTROL in, it would studder and make tons of noise. Any suggestions would be appreciated.
Thanks,
Thanks,
Acrad (11-14-22)
#1259
Thanks,
Thanks,
#1260
I changed the crawl speed and it didn't change the studdering at all. I couldn't go 3 inches, the car completely locks up.
