Replacing Broken Turn Signal Housing
Old 08-13-17, 05:04 PM
BigGreen13
BigGreen13's Avatar
Default Replacing Broken Turn Signal Housing
Hey all, quick question that I hope you can help with. I drive a good bit (40k/year) and debris is bound to happen. My right turn signal housing got cracked, and a rain storm I drove through forced some water in there which turned brown, not the best sight. The turn signal lamp still works fine. I want to replace the lens cover, and I bought the part for about 65 bucks. The dealer tells me they have to take apart the whole bumper assembly so replacing this will be over 300 bucks. I tend to call BS. Can anyone tell me if this is an easy enough DIY or do I need to let the dealer rake me over the coals for a lens cover?
Thank you all, in advance.
2016 GX 460 Premium
Old 08-13-17, 05:21 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,637 Likes on 2,383 Posts
FYI: Removing the bumper cover is what they list in FSM for swapping that housing. Always a chance someone has found an easier way though.
Old 08-13-17, 06:53 PM
BigGreen13
BigGreen13's Avatar
Bummer! How difficult is that as a DIY?
Old 08-13-17, 07:54 PM
Acrad
Super Moderator
Acrad's Avatar
I don't think I have seen anyone do a writeup on that one. Possibly on one of the other Toyota off-road forums.
Old 08-13-17, 07:57 PM
Acrad
Super Moderator
Acrad's Avatar
Personally...I'd try to see if there was a way to change via removal of wheel-well splash molding.
Old 08-13-17, 08:09 PM
BigGreen13
BigGreen13's Avatar
Definietely going that route versus removing the front bumper. Worth the money to avoid that.
Old 05-06-20, 06:16 AM
Acrad
Super Moderator
Acrad's Avatar
Old 05-06-20, 08:04 AM
nuclearn8
nuclearn8's Avatar
My experience with removing the turn signal housings for sound dampening is you can bend the 3 longer tabs all you want but the light won't come out... those are there to help locate the shorter pieces which need pushed with a small screwdriver to release the light housing with some jiggling....discussed in the below thread...
https://www.clublexus.com/forums/gx-...ssistance.html
The following 2 users liked this post by nuclearn8:
Acrad (05-06-20), cb1111 (05-08-20)
richie3888
09-15-11 11:48 AM
jbodie
GX - 1st Gen (2003-2009)
08-20-09 06:07 AM
kingloose
10-07-07 06:07 PM
ebandaz
Lighting
02-19-04 10:35 AM
Quick Reply: Replacing Broken Turn Signal Housing
