Illuminated Door Sills
Old 08-18-17, 05:57 PM
naser075
naser075's Avatar
Default Illuminated Door Sills
so i just saw that only my drivers side illuminated door sill is working ,
is that normal or should they all be working??? is it a hard removal to change the led light or any lighting that needs to be changed
thank you
Old 08-19-17, 08:00 AM
Acrad
Super Moderator
Acrad's Avatar
Received 3,652 Likes on 2,391 Posts
Just the fronts light up and they should both be on. Not sure if LED is serviceable... one may need to solder in a new one if bulb is actually out.
Old 08-19-17, 09:28 AM
naser075
naser075's Avatar
oh my god ,... thank u so much
Old 02-04-18, 12:04 PM
golfeus
golfeus's Avatar
Hi,
Was the illuminated door sill part of the premium GX or do all the 2nd generation illuminate? I just bought a used 2013 last Dec with 75k miles and neither sill has ever lite up. Pulled off the drivers door sill to replace it due to multiple dents and I don't see any led or bulb of any kind although there's a plug I had to undo. Please see attachment. Is this some type of light or just a terminator?
I appreciate any help with this!
Old 02-04-18, 12:12 PM
Acrad
Super Moderator
Acrad's Avatar
EDIT: Probably the plug to add them.
https://www.toyotapartsdeal.com/oem/...0980-11002.htm
Premium option
GX Brochures
2010
http://www.lexus.com/documents/broch...X-Brochure.pdf
2011
2012
2013
2014
2015
2016
2017
2018
https://www.lexus.com/documents/broc...X-Brochure.pdf
Part Numbers:
Black-Right
67910-60080-C0
Black Left
67920-60080-C0
Sepia-Right
67910-60080-E0
Sepia-Left
67920-60080-E0
golfeus (02-04-18)
Old 02-04-18, 12:20 PM
tecman
tecman's Avatar
Plastic blank. I pulled up my door sills and didn't notice that but I was not looking for it.
golfeus (02-04-18)
Old 02-04-18, 12:35 PM
golfeus
golfeus's Avatar
I was afraid that was the case!
Old 02-05-18, 07:01 AM
GB2011GX
GB2011GX's Avatar
All you people punching up all these gadgets and trinkets that are only on the Premium models are depressing me. JK
Have fun with your gadgets!
Old 02-05-18, 05:44 PM
golfeus
golfeus's Avatar
That's the truth!!!
Old 06-13-21, 11:35 AM
Acrad
Super Moderator
Acrad's Avatar
I know this is an old thread but is basic connector there with the terminator plug above on all non-equipped models?
My memory on this is a little cloudy. It seems from early posts that all 10-13 have connector but only the "equipped" '14+ Luxury have connector.
Old 11-26-21, 04:28 PM
Seanzky
Seanzky's Avatar
I removed my driver's door sill to remove a piece of Weathertech window visor that had broken off and fallen in there --I was afraid of rattling so it was important that I remove it. I did NOT see any connectors, just a loom that was neatly wrapped/taped. I slightly damaged the scuff plate itself and was considering replacing it with illuminated ones. The metal part separated from the plastic (one plastic tab had broken off), had 4 small dents, etc. I'll just leave it on until there are more dents and scratches and I'll take a look again. The truck is still too brand new.
Old 11-26-21, 05:48 PM
MrTorgue
MrTorgue's Avatar
Both front door sills seem to have a connector that connects to the factory unlit sill plates. Does this mean both of my doors have the capability of illuminated door sill plates? If so do they make rear illuminated sills I could wire up to the door open sensor button or interior dome light?
Old 11-26-21, 06:17 PM
Acrad
Super Moderator
Acrad's Avatar
Can you take a meter to what is there to see if you have 12V?
Old 11-27-21, 04:29 AM
nuclearn8
nuclearn8's Avatar
The front sill plates are plug n play option. Every GX has the connectors, just plug the parts in, walla.
No idea on the rear sill plates... let us know what you find out.
MrTorgue (11-27-21)
Old 11-27-21, 05:17 AM
Acrad
Super Moderator
Acrad's Avatar
It should be easy to wire up but not sure about all being pre-wired…. OP back in ‘13 didn’t find connectors on their ‘14 Premium
Quick Reply: Illuminated Door Sills
