Barn Door Latch Malfunction - Stuck open or closed
Old 08-10-17, 11:15 AM
tecman
tecman's Avatar
The latch has gone bad for a few people here.
https://www.clublexus.com/forums/gx-...-t-unlock.html
https://www.clublexus.com/forums/gx-...wing-door.html
LexusRednk (08-10-17)
Old 08-10-17, 11:25 AM
LexusRednk
LexusRednk's Avatar
Same issues in NH as in Minnesoter. Mine opened, but would close. Got it apart and am going to uber lube it..
Old 08-19-17, 09:24 AM
Fridaygold
Fridaygold's Avatar
Default Rear door handle does not release - unable to close rear door
I have a 2011 Lexus GX460. The rear door handle gets "stuck" in what I am going to call the "open" position, preventing the door from closing.
I use a screw driver and press on the inner part of the handle which releases the handle. I push the door close so the latch catches.
I do not see any way on how to get to the inner workings of the door to lube the handle. Appreciate the insight of this group. Thanks!
Old 08-20-17, 11:16 AM
Fridaygold
Fridaygold's Avatar
Exclamation Barn Door Latch Malfunction - Stuck open or closed
Old 08-20-17, 01:11 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,652 Likes on 2,391 Posts
This thread will probably help.
https://www.clublexus.com/forums/gx-...l-removal.html
tecman (08-20-17)
Old 08-20-17, 01:24 PM
tecman
tecman's Avatar
Thanks Acrad, forgot where this thread was.
Old 08-20-17, 01:29 PM
Acrad
Super Moderator
Acrad's Avatar
I did too... I think I found the link in a thread you had re-posted it to. ... Thank you! :-)
Old 08-20-17, 03:00 PM
User21c
User21c's Avatar
Originally Posted by logix7
wrong forum guy
This is the GX 2010+ forum... How was it the wrong one?
Old 08-20-17, 03:09 PM
tecman
tecman's Avatar
moved here by a forum moderator. Common practice and not always stated by the mod.
Old 08-20-17, 03:17 PM
User21c
User21c's Avatar
Ahhhh.... thanks.
Old 08-22-17, 07:54 AM
GX4602011
GX4602011's Avatar
Mine does that on the rear door (cargo area, swing door), I just press the inner part of the handle back into position like you do (but with my fingers). I think it's from dust in my case, as it started to do it right after driving 50 or so miles of dusty unpaved roads. Not sure what I'll do about it at this time, may just take the rear door inner panel off to get access to the handle and clean the area (I haven't been in there so don't know the procedure).
Old 08-22-17, 08:24 AM
516IS
516IS's Avatar
I have the same issue, wonder if there is a quick fix.
Old 08-22-17, 11:25 AM
clevercat
clevercat's Avatar
I had a same problem in my 2013 with 60K miles.
I had to replace the door actuator switch.
Dealer said it is common problem for GX.
Old 08-22-17, 11:55 AM
516IS
516IS's Avatar
Did you replace this yourself? any DIY info?
Old 08-22-17, 03:11 PM
Stars33
Stars33's Avatar
When I bought my 2013 a few weeks ago, this was an issue. I was just pushing straight back in with my fingers to put the latch back in "closed" position, which worked OK, but was a hassle (but you shouldn't have to use a screwdriver - unless it's a different issue). Last week I injected a little spray oil into the small openings by the handle and into the small mechanism opening by the interior door latch, and worked it back and forth. Seems to be working fine now. Hope this helps. I'm sure a new latch is the answer, but this could get you buy for now.
Quick Reply: Barn Door Latch Malfunction - Stuck open or closed
