Locking a 2014 GX while engine is running?
Hi all,
I live in Arizona and have the need to lock my '14 GX460 while the engine is running. Does anyone have any information how I may do this?
Key fob won't lock and neither will the door handle sensors while engine is running.
What am I missing?
Thanks,
What am I missing?
Thanks,
Don't know if this would work for you but I can unlock the driver door with the metal key, start the truck, exit and lock the door with the metal key.
Make sure you roll down your windows when testing in case you get locked out.
It is designed that way to prevent anyone from locking their keys in the vehicle by accident.
As mentioned before, I believe you can use the metal key to lock and unlock wile running.
Good luck.
George
Good luck.
George
