If mine ever starts doing this I will probably try to adjust this first up or down just a small amount to see if it helps. Then head for the tape method. :-)
I need help....I know this sounds trival but I have a sweak that sounds like its coming from the rear window and I have wd-40'd every bolt and hinge I can find. Only thing I havent yet tried is a rubber rejuvenator on the door and window seals and the two little rubber pads that the window rests on. I swear I'm only making this thread because I'm going to burn the f@#$%&# thing to ground if I have to keep driving with this constant sweak. Anyone who may have encountered this before that can help, would be greatly appreciated. Thanks for your time.
