Boat, Travel or Other Trailer Towing Experiences
Old 10-16-17, 02:36 PM
  #166
Acrad
Super Moderator
Acrad's Avatar
Received 3,639 Likes on 2,384 Posts
HRDave: Post some pics when you get back. Thanks!
Old 10-16-17, 02:51 PM
  #167
Acrad
Super Moderator
Acrad's Avatar
This looks like Airstream model in brochure
http://www.rvnetlocator.com/view-201...ails-m2ik.html
Base weight is 3852lbs.
https://www.airstream.com/travel-tra...oud/floorplan/
It's plenty doable with the GX.
meitzler (10-18-17)
Old 10-18-17, 08:42 AM
  #168
meitzler
meitzler's Avatar
I would be very interested in the feedback from those towing a 22' travel trailer with the GX. So please post your impresssions. What speed did you drive. How were the hills. And, the gas milage.
Old 10-18-17, 09:23 AM
  #169
HRDave
HRDave's Avatar
Default 2018 Winnie Minnie Micro
Here's what I'll be pulling. Should hear from Winnebago tomorrow if she's ready!
I'm ready to get it out on the road for her maiden voyage before I have to put her away for the winter!
Old 10-18-17, 11:09 PM
  #170
Oldmanb777
Oldmanb777's Avatar
I think having correct tongue weight, and a good hitch setup, then driving sanely (like anyone knows how to do that) is the key. DOT has some good info on their website about towing, and tongue weight etc. What does that weigh when fully loaded?
Old 10-19-17, 11:00 AM
  #171
GB2011GX
GB2011GX's Avatar
Here's the deal... it's not so much tongue weight and over-all weight (depending on axles and trailer brakes). I tow my 32' 6,700 Lbs Coachmen Freedom Express with my 6,500 Lbs Ford F-150 all the time just fine. The trailer has dual axle and each wheel has electric brakes. The truck has the brake control module added to amplify the power to the rear hook-up upon braking.
The REAL issue (IMHO) is sway. I use a load-leveling hitch with anti-sway brake. This helps transfer weight off the tongue and position the fulcrum to between the axles for even braking, The emergency disconnect would lock up the trailer brakes if the tongue or hitch ever failed.
The real danger is sway which best explained is this... Do you really want 7,000 Lbs of fish-tailing trailer behind you, and pulling your vehicle off the road?
Oldmanb777 (10-19-17)
Old 10-19-17, 11:07 AM
  #172
Acrad
Super Moderator
Acrad's Avatar
For those that don't know...sway control algorithm was added to stability control system starting with '14 models
GB2011GX (10-19-17)
Old 10-23-17, 07:18 PM
  #173
meitzler
meitzler's Avatar
The feedback that I am seeking assumes electric breaks with a controller in the GX, a weight distribution hitch, and optional sway control attachment. Proper setup is important no matter what vehicle is pulling the trailer.
Old 10-30-17, 01:44 PM
  #174
HRDave
HRDave's Avatar
Default Back From The Maiden Voyage!
Well the GX did great! Pulled very well. I discovered that, especially in the hills of Kentucky, S Mode is the way to go for the transmission. It gives you a lot of control and doesn't get confused as to what gear the GX should be in.
In Automatic Mode, the transmission would actually get confused as to what gear was the best. When ascending long hills on the interstate I would put it in S Mode 4 and leave it there running at about 2800RPM at 65 mph. Perfect!
Downhill, back to Auto and descent was fine. Level highway and Auto was perfect. Start and Stop in town I used S mode most of the time. It just felt more efficient and strong. Back roads pretty much S Mode the whole time adjusting for speed.
The GX has great torque and I averaged 11 mpg. going 65-70 mph. I never had any sway problems whatsoever. The sway control bar never left my storage bin.
I meant to take a picture of my hitch set up, but I was too busy having fun camping and forgot. It's a Reese Pro Series w Friction Sway Control (didn't use) with a Draw-Tite 5504 Brake Controller.
The only issue was at slow speeds the electric brakes were a little grabby on the trailer and lurched a little, but was tolerable.
Overall a very pleasant experience and confirmed why I chose the GX 460 for my tow vehicle.
The following 4 users liked this post by HRDave:
Acrad (11-01-17), daxia (03-11-18), RRrider (03-11-18), sinistar (05-29-19)
Old 01-09-18, 01:27 PM
  #175
shabakand
shabakand's Avatar
Default Towing a Jeep with the GX460
I am a new owner of a 2018 Lexus GX460. I have a question regarding towing with this vehicle. I have a lifted jeep wrangler that weighs roughly 4000 lbs. Other than looking extemely awkward, would there be any issues flat towing my jeep. I included a picture of the jeep behind the Lexus. Thanks in advance for all who chime in!
Attached Thumbnails Boat, Travel or Other Trailer Towing Experiences-img_1454.jpg
Old 01-09-18, 03:26 PM
  #176
Acrad
Super Moderator
Acrad's Avatar
You should be able to do that. I assume the trailer you will be towing with has electric brakes? Have you already installed the brake controller in GX?
Old 01-09-18, 03:50 PM
  #177
shabakand
shabakand's Avatar
Actually, I wouldn't be using a trailer, but would be flat towing using a tow bar. All four wheels of the jeep will be on the ground......
Old 01-09-18, 04:20 PM
  #178
Acrad
Super Moderator
Acrad's Avatar
I've only ever done a shy under 3K lbs because that is legal in WA state.
Looks like in CA anything over 1500lbs needs to have supplemental brakes for what is behind you.
http://www.brakebuddy.com/towing-laws
Old 03-06-18, 11:45 AM
  #179
HopRock
HopRock's Avatar
Default What are you towing?
I've poked around to see if there was a dedicated Towing thread or Sub-forum, but not having any luck; Curious to see what those who do tow are pulling with their 2nd Gen GXs.
Let's see 'em!
HR
Old 03-06-18, 01:39 PM
  #180
Acrad
Super Moderator
Acrad's Avatar
Take a look at this thread
https://www.clublexus.com/forums/gx-...xperience.html
Quick Reply: Boat, Travel or Other Trailer Towing Experiences
