Timing Cover Oil Leak
#166
Romanova (07-23-20)
#168
Can you help? Possible leaking engine...
Recently purchased this GX460 from carmax. Love it but discovered this goo, leak, or whatever in the front of the engine. I know these engines can have a leak, timing cover. Is that what I am look at here? Appreciate any help!
Top down view
bottom up view
Top down view
bottom up view
#170
How's your engine oil level?
That vehicle appears to have experienced some really sloppy engine oil refills during the change OR it has a timing cover leak. you can check that thread to see if it's leaking in the same general area... hard to tell from the posted pictures....
#171
That is a typical area around AC compressor that timing chain cover leaks.
https://www.clublexus.com/forums/gx-...-oil-leak.html
That should be fixed by Carmax under that 90 day 4K warranty.
https://www.carmax.com/car-buying-pr...-service-plans
dwh13 (10-21-20)
#174
At my last oil change, the Lexus dealer said I have a small leak at the timing cover.....like many of us. I called this local shop called Carspec in Minneapolis. They have this really nice article about the issue:
http://carspecmn.com/gx460-oil-leak-...ver-explained/
I talked to John and he said he has over 50 customers who have the same issue and have told them they don't need to spend the $2200-$2800 to replace the gasket. Its a nuisance oil drip. He said if it doesn't bother you, then save your money.
The following 2 users liked this post by maduro:
Acrad (10-21-20),
FireAgateP (10-22-20)
The following 2 users liked this post by tecman:
Acrad (10-21-20),
#177
Took it to the dealer today. They said it's seeping, not leaking out and that it is not a problem. It's a "known" thing with these engines and they said it didn't need to be fixed.
IDK seems odd to have a "seeping" oil leak and not want to fix it...thoughts?
#178
Does he mean save your money cuz your going to have to fix it eventually? or save your money as in you won't ever have to fix it?
A bit annoyed as my warranty will run out in 70 days, 3k miles...would like to get it fixed now, while it's covered..
#179
If you check the timing chain cover leak thread there is criteria the dealers use.
That said, no engineer, designs an engine to leak or seap oil. The oil is meant to lubricate and cool the engine internals...
Being an engineer, I also believe 99% of the time this particular issue will not lead to a catastrophic failure, it's a manageable chronic condition. So long as your engine oil level is good, you're ok.
clean up the engine once in a while... you should be good longterm.
Acrad (10-22-20)
