what oil do u use for a 2012 GX 460
Old 10-31-17, 12:50 PM
rmoham
rmoham's Avatar
Default what oil do u use for a 2012 GX 460
rmoham is offline
Old 10-31-17, 02:37 PM
bbqsoup
bbqsoup's Avatar
I just bought 4 5-qt jugs of Mobil1 EP 0W-20 and plan to change the oil in the next few weeks or so. I think any big names synthetic oil will do. Toyota/Lexus is using bulk oil from a big drum anyway.
Btw Walmart is having a rebate for Pennzoil Ultra Platinum or Platinum if you can find the grade.
bbqsoup is offline
Old 10-31-17, 03:52 PM
Greysmoke
Greysmoke's Avatar
I can't find a source specifically for 2012, but I found this: "Most Lexus have the oil type printed on the oil cap - it will likely be 5W-20, 5W-30, 5W-40, 10W-30 or 10W-40." Unfortunately my son is driving my '14 GX460 at this moment - somewhere - so I can't look into this myself. Maybe give it a try.
Greysmoke is offline
Old 10-31-17, 04:00 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,638 Likes on 2,383 Posts
I use
Acrad is offline
Old 10-31-17, 07:05 PM
Dallasguy1
Dallasguy1's Avatar
I use 0w20 mobil1 from walmart and the oem filter from the dealer. Have a 2012 aswell.
Dallasguy1 is offline
Old 11-02-17, 01:17 PM
Craigyyy
Craigyyy's Avatar
From the manual:
Toyota Genuine Motor Oil” is used in your Lexus vehicle. Use Lexus approved “Toyota Genuine Motor Oil” or equivalent to satisfy the following grade and viscosity.
Oil grade: ILSAC multigrade engine oil
Recommended viscosity: SAE 0W-20
SAE 0W-20 is the best choice for good fuel economy and good starting in cold weather. If SAE 0W-20 is not available, SAE 5W-20 oil may be used. However, it must be replaced with SAE 0W-20 at the next oil change.
The 0W portion of the oil viscosity rating indicates the characteristic of the oil which allows cold startability. Oils with a lower value before the W allow for easier starting of the engine in cold weather. The 20 in 0W-20 indicates the oil viscosity when the oil is at its operating temperature. An oil with a higher viscosity may be better suited if the vehicle is operated at high speeds, or under extreme load conditions.
I buy Mobil 1, and use a factory Lexus/Toyota filter.
Last time I thought I had a couple jugs of Mobil 0W-20, and after I had drained and changed filter, I realized I had mistakenly double bought mobil 5W-20, which is what our MDX takes. I plan to put 0W-20 in next time.
Craigyyy is offline
Old 11-03-17, 06:06 AM
texas008
texas008's Avatar
oem filter, 0w20 (mobile 1 or Pennzoil, or genuine toyota engine oil)
texas008 is offline
Old 11-03-17, 01:50 PM
pathfinder
pathfinder's Avatar
Mobil 0W-20 Extended Performance. oil change every 10k miles.
pathfinder is offline
Old 11-07-17, 09:07 PM
caesosa
caesosa's Avatar
I noticed at my local Napa they had some unusual oil that is typically hard to find.
They had LiquiMoly which I use for a german car and Eneos which I have heard good thing about for Japanese engines.
Has anyone tried the Eneos for the GX?
side note, they also had Amsoil which I hadn’t seen at O’reilly or Autozone. Not sure if it is just some Napa stores that carry it but I thought it was cool.
caesosa is offline
Old 11-07-17, 09:22 PM
Acrad
Super Moderator
Acrad's Avatar
I haven't used Eneos in my GX but I have heard high praise of it. It has a high moly count like the stock Mazda oil (Idemitsu) I use in my CX-5.
Acrad is offline
satiger
07-10-15 02:32 AM
Turbinator
GX - 1st Gen (2003-2009)
09-08-09 07:16 AM
BobsGX
Maintenance
75
09-04-06 10:58 PM
CdeFabio
02-23-05 07:16 AM
Quick Reply: what oil do u use for a 2012 GX 460
