USB/Aux not working...not fuse
Old 11-11-17, 02:44 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,654 Likes on 2,392 Posts
'14+ you will want PN: 86190-53051
Quite a bit more as a new part
One on eBay... interesting... "“Removed from a new IIHS test car”"
Acrad is offline
ac2000GX (11-11-17)
Old 11-11-17, 03:44 PM
tecman
tecman's Avatar
I would test power before assuming it is a part that needs to be ordered. The USB port has an outer piece that is the ground (what my black lead is on). I tied a 22 gauge wire to the positive tester lead to fit it in there.
tecman is offline
ac2000GX (11-11-17)
Old 11-11-17, 04:24 PM
Acrad
Super Moderator
Acrad's Avatar
tecman: good point on power test
EDIT: Good meter... not sure if that model is made there but I drive by the Fluke plant in Everett, WA everyday
If you aren't comfortable with a multi-meter you can always pick up one of these cheap testers too
https://www.ebay.com/i/271999629267?chn=ps&dispctrl=1
Acrad is offline
ac2000GX (11-11-17)
Old 11-11-17, 08:06 PM
ac2000GX
ac2000GX's Avatar
Thanks everyone... you guys are amazing... I'll look into testing it and getting a replacement part if needed!
ac2000GX is offline
Old 11-14-17, 04:03 PM
Acrad
Super Moderator
Acrad's Avatar
Originally Posted by tecman
Been a while since I took this off 1:13 min. Guess I am getting slow.
https://www.youtube.com/watch?v=iDC17by41s8&feature=youtu.be
tecman: Do you know if the cup holder piece also swaps really easy once you have pulled up piece in your video? I incurred some damage on the wood piece cover and found a perfect used one for less than 1/4 of the new price of $450+ new. I think it does from FSM. I need to check out the thread on the USB port install for rear passengers as I think that part was removed too.
Thanks!
EDIT: Jacket has a post showing it lifts out
EDIT2: It am pleased that whole console comes apart as easily as it does. To remove the center cupholder assembly all you have to do is slightly lift up the panel with the gear shift, pop out the side covers maybe 3 tabs, lift up the center store cover and pull straight up. There is the electrical connector for the cupholder lights but that seems to be the hardest part of this easy process.
Acrad is offline
Old 12-03-17, 04:20 PM
ac2000GX
ac2000GX's Avatar
Hey guys - so I bought the USB power tester off of ebay, and it appears there's no power coming from the USB/aux port. So what does that mean? Wiring issue? Replacing the adapter would not help then?
ac2000GX is offline
Old 12-04-17, 12:26 AM
Acrad
Super Moderator
Acrad's Avatar
You probably have to meter it out up the line. The console opens up pretty easily. You may want to see if the connector just got disconnected from underside of auxiliary USB jack
Acrad is offline
Old 12-04-17, 11:10 AM
Htony
Htony's Avatar
If it was working jack, wonder if a device drawing too much current was plugged into it. As mentioned trace the wire (or ribbon cable) all the way to USB controller.
Htony is offline
Old 12-05-17, 09:14 PM
ac2000GX
ac2000GX's Avatar
How would I know if the adapter itself is broken or not, and simply not passing the power through? And what do I look for when I trace the wire back to the USB controller? Just to see if anything is unplugged? I did open it before and saw that it was plugged to the adapter, though I didn't trace it all the way back to the controller.
ac2000GX is offline
Old 12-06-17, 11:07 AM
brian4l
brian4l's Avatar
I'd like to resurrect this and ask about the console cover that's silver on base models like the one in the video. I have found a replacement cover I think and wanted to know how easy it would be to replace? Attached the boot, buttons and whatnot, right? Are is it all one unit? The one I have now is scuffed up and damaged.
brian4l is offline
Old 12-06-17, 11:50 AM
tecman
tecman's Avatar
4 wiring clips (small writing says USB unplugged for better picture). Then just clips and screws
tecman is offline
Acrad (12-06-17)
Old 12-06-17, 12:34 PM
brian4l
brian4l's Avatar
Wow, thank you!
brian4l is offline
claybaybay
03-07-19 03:29 PM
stothjr
HS 250h Model (2010-2012)
11-09-15 07:07 AM
NguyenD408
SC- 1st Gen (1992-2000)
01-17-09 05:58 PM
lenunn1923
08-21-08 06:33 PM
Quick Reply: USB/Aux not working...not fuse
