USB/Aux not working...not fuse
Old 11-06-17, 10:31 PM
ac2000GX
ac2000GX's Avatar
Default USB/Aux not working...not fuse
As the title states - my USB and AUX ports aren't working. I checked the fuses and they are ok. Any thoughts?
ac2000GX is offline
Old 11-07-17, 09:37 AM
bbqsoup
bbqsoup's Avatar
It could be the connector is loose. You can pop the side panel on the middle console out and check.
bbqsoup is offline
Old 11-07-17, 09:53 AM
ac2000GX
ac2000GX's Avatar
Thanks... do I need special tools to pop out the side panel?
ac2000GX is offline
Old 11-07-17, 10:04 AM
Htony
Htony's Avatar
Tried different USB device/cable?
Htony is offline
Old 11-07-17, 10:11 AM
ac2000GX
ac2000GX's Avatar
I did try different a USB device/cable but it didn't work. Thanks for the idea though. The "Aux" tab is in gray on the display screen too. So maybe loose connector or just faulty usb/aux thing?
ac2000GX is offline
Old 11-07-17, 03:05 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,654 Likes on 2,392 Posts
This may help
Acrad is offline
Old 11-07-17, 03:51 PM
tecman
tecman's Avatar
Been a while since I took this off 1:13 min. Guess I am getting slow.
https://www.youtube.com/watch?v=iDC1...ature=youtu.be
tecman is offline
Old 11-07-17, 08:06 PM
ac2000GX
ac2000GX's Avatar
WOW - you guys are amazing. Thank you!
ac2000GX is offline
Old 11-09-17, 04:03 AM
naser075
naser075's Avatar
i had the same problem about 2 months ago and asked the same question here that is what u have to do :
https://www.clublexus.com/forums/gx-...oval-help.html
naser075 is offline
Old 11-09-17, 07:54 PM
ac2000GX
ac2000GX's Avatar
Thanks naser - so did the Lexus tech do what was in the video from this thread? Unscrew the gear shift and pop out the bottom piece?
ac2000GX is offline
Old 11-10-17, 04:51 AM
naser075
naser075's Avatar
no he took out the side ones then just lifted the part where shifter is ,... he did unscrew the shifter and putt it on N before hand ,.. .all that really quick am telling u less then 45 sec
naser075 is offline
Old 11-10-17, 08:21 PM
ac2000GX
ac2000GX's Avatar
Ok - so I popped out the console area underneath the shifter and the USB/Aux port and... it was plugged in properly.
I even unplugged it and plugged it back in just in case. Restarted the car and the port still isn't working or showing up. Any other thoughts anyone? Bad port, or wiring, or could be anything I guess?
ac2000GX is offline
Old 11-11-17, 03:38 AM
naser075
naser075's Avatar
at this point change the plug itself the hole unit it is fairly expensive but u can find it on eBay for cheap,... also to be honest i find this USB port has no real use to it even after i fixed mine i don't ever use it
naser075 is offline
Old 11-11-17, 07:43 AM
Acrad
Super Moderator
Acrad's Avatar
Not sure what year you have but one for '10-'13 is priced here at $111.46
PN: 86190-53040
Some used ones on eBay for around $40
Acrad is offline
Old 11-11-17, 08:59 AM
naser075
naser075's Avatar
yes that is the one i bought it also but returned to toyota since lexus was selling it more expensive then toyota
naser075 is offline
Quick Reply: USB/Aux not working...not fuse
