Auto folding mirrors
Old 04-10-19, 10:24 AM
  #226
elkaboing
elkaboing's Avatar
Just received a message from the seller of the WINSGO on Aliexpress saying the window functions cannot be disabled - just an FYI for anyone else looking to purchase one of these.
Old 04-20-19, 06:24 PM
  #227
Funk101
Funk101's Avatar
Default Accidentally discovered (new?) feature on WINSGO
This is new to me. Not sure if anybody has used this feature but just in case:
When I quickly click the key fob “unlock” button four times the doors unlock, all four windows simultaneously roll down, the moonroof stays closed, the mirrors fold out. It’s four quick clicks without holding the button down.
If I wait a few seconds (or a minute) without opening the doors, the windows stay open, doors lock (and I guess the hatch as well, I haven’t verified), and the mirrors stay open.
Then if I click the “lock” button on the key fob the doors stay locked, the windows roll up, the mirrors fold in.
(This is on a 2017)
Old 08-02-19, 08:13 AM
  #228
Richard776
10th Gear
Richard776's Avatar
Default help
Originally Posted by Otherone
I just received this module from Aliexpress: WINSGO Car OBD Window Closer Open+ Side Mirror Fold Spread LHD Left Hand Drive For Lexus GX 2014+ and works perfectly. Specified I did not want it to flash while locking/unlocking when I ordered.
Took a quick video for anyone interested (ignore the food truck generator in the back ground): https://youtu.be/yiLsQ2UeXYQ
So I bought this and plugged into the OBO is there something else I need to do? It's not working
Old 08-02-19, 08:14 AM
  #229
John00
John00's Avatar
make sure the mirror switch is not centered, set it to left or right adjust mode
^^incorrect
Old 08-02-19, 09:34 AM
  #230
hzhao
hzhao's Avatar
That switch should have nothing to do with it. Mine is always in the center. The module is plug and play, there is nothing else need to set.
Old 08-02-19, 09:42 AM
  #231
John00
John00's Avatar
OK I though on mine it did, maybe i'm confusing another car? I'll double check later and report what I find.
Old 08-02-19, 12:42 PM
  #232
hzhao
hzhao's Avatar
The mirror control switch in the center position will only disable the reverse tilted down feature.
John00 (08-02-19)
Old 08-02-19, 01:26 PM
  #233
krazykrnbo
krazykrnbo's Avatar
Might be defective. Mine just was a plug and play. Nothing more done needed.
what hzhao stated - mirror switch has nothing to do with the module working or not working.
Old 08-02-19, 01:29 PM
  #234
John00
John00's Avatar
I was incorrect, that switch is not needed.
Are you locking the doors?
Old 08-02-19, 06:31 PM
  #235
cb1111
cb1111's Avatar
Just as an aside, having the windows close via remote is not allowed in the US unless the remote has extremely short range. Accordingly, this mod is in violation of Federal Motor Vehicle Safety Standard (FMVSS)118
For most people, this is a technicality but if an accident does occur then there could be significant legal issues and there is a chance (albeit minuscule) that the car may fail inspection if the station actually checks.
Old 08-02-19, 08:00 PM
  #236
Acrad
Super Moderator
Acrad's Avatar
Received 3,638 Likes on 2,383 Posts
Fairly subjective distance... "(e.g., by use of a limited-range remote control),"
Is that within sight distance? I only operate mine within 5-10 feet of vehicle.
Old 08-02-19, 08:14 PM
  #237
cb1111
cb1111's Avatar
That is a great question and the regulation has the answer - no more than 6 meters which is about 20 feet - the theory being that you should be able to see if a child or dog has a body part hanging out of the window. The Lexus remote has a far greater distance.
While I wasn't involved in that portion of SAFETEA-LU (and certainly not for the name), I reviewed it for National Security implications (part of the normal rulemaking process).
Old 08-02-19, 10:38 PM
  #238
Acrad
Super Moderator
Acrad's Avatar
Unfortunate this regulation hasn't been updated for the anti-pinch/jam protection functionality built into most modern power window installations that auto reverse on obstruction.
460 FSM states---> "Uses Hall-IC in regulator motor with ECU to detect window position and jamming."
Old 08-03-19, 08:52 PM
  #239
Ralo14
Ralo14's Avatar
Seems cool in the videos but I would rather the mirrors fold in when the vehicle is turned off like on my LS430.
Old 08-04-19, 04:44 PM
  #240
cb1111
cb1111's Avatar
Actually it does.The regulation requires in S5:
S5. Automatic reversal systems. A power-operated window, partition, or roof panel system that is capable of closing or of being closed under any circumstances other than those specified in S4 shall meet the requirements of S5.1, S5.2, and, if applicable, S5.3.
S5.1. While closing, the power-operated window, partition, or roof panel shall stop and reverse direction either before contacting a test rod with properties described in S8.2 or S8.3, or before exerting a squeezing force of 100 newtons (N) or more on a semi-rigid cylindrical test rod with the properties described in S8.1, when such test rod is placed through the window, partition, or roof panel opening at any location in the manner described in the applicable test under S7.
S5.2. Upon reversal, the power-operated window, partition, or roof panel system must open to one of the following positions, at the manufacturer's option:
(a) A position that is at least as open as the position at the time closing was initiated;
(b) A position that is not less than 125 millimeters (mm) more open than the position at the time the window reversed direction; or
(c) A position that permits a semi-rigid cylindrical rod that is 200 mm in diameter to be placed through the opening at the same location as the rod described in S7.1 or S7.2(b).
S5.3. If a vehicle uses proximity detection by infrared reflection to stop and reverse a power-operated window, partition, or roof panel, the infrared source shall project infrared light at a wavelength of not less than 850 nm and not more than 1050 nm. The system shall meet the requirements in S5.1 and S5.2 in all ambient light conditions from total darkness to 64,500 lux (6,000 foot candles) incandescent light intensity.
S4 ( referenced in S5) requires:
S4. Operating requirements. Except as provided in S5, power operated window, partition, or roof panel systems may be closed only in the following circumstances:
(a) When the key that controls activation of the vehicle's engine is in the “ON”, “START”, or “ACCESSORY” position;
(b) By muscular force unassisted by vehicle supplied power;
(c) Upon continuous activation by a locking system on the exterior of the vehicle;
(d) Upon continuous activation of a remote actuation device, provided that the remote actuation device shall be incapable of closing the power window, partition or roof panel from a distance of more than 6 meters from the vehicle;
(e) During the interval between the time the locking device which controls the activation of the vehicle's engine is turned off and the opening of either of a two-door vehicle's doors or, in the case of a vehicle with more than two doors, the opening of either of its front doors;
(f) If the window, partition, or roof panel is in a static position before starting to close and in that position creates an opening so small that a 4 mm diameter semi-rigid cylindrical rod cannot be placed through the opening at any location around its edge in the manner described in S5(b); or
(g) Upon continuous activation of a remote actuation device, provided that the remote actuation device shall be incapable of closing the power window, partition or roof panel if the device and the vehicle are separated by an opaque surface and provided that the remote actuation device shall be incapable of closing the power window, partition or roof panel from a distance of more than 11 meters from the vehicle.
John00 (08-04-19)
Quick Reply: Auto folding mirrors
