Auto folding mirrors
Old 04-04-22, 09:06 PM
  #316
BillWill87
BillWill87's Avatar
Originally Posted by obadea
I have it in my 2020. Remote start your car through the remote app and let the 10 minutes run out. See if your alarm goes off when the engine shuts down.
It won't drain your battery, btw.
I'll report back and let you know if that happens to mine
Old 04-08-22, 05:17 AM
  #317
BillWill87
BillWill87's Avatar
So I noticed that mine does that too. It also triggers the alarm if I unlock the door. I wonder if you found a work around of the alarm if the car was in remote start and hasn't lapsed the 10 minutes. I usually just do 5 minutes before getting into the car so I would love to know if there was a work around for this.
2eXceL (05-25-24)
Old 04-08-22, 06:01 AM
  #318
obadea
obadea's Avatar
I am not aware of a fix, not sure if there's a way to report this to the company that makes it.. I wired mine via a switch, so I can turn it off, and I mostly keep OFF now.
2eXceL (05-25-24)
Old 04-08-22, 07:48 AM
  #319
tntcandy
tntcandy's Avatar
I don't use remote start, so haven't had any issues with the auto folding module, works every time.
Old 04-21-22, 04:50 PM
  #320
EJC
EJC's Avatar
Originally Posted by BillWill87
Guys! I got this yeterday and installed it in my 22' GX and it works like a charm! Basically it folds and unfolds when you lock/unlock the car and few other cool features.
->Question that I have is, will this will drain your battery when the car is turned off.? Anyone out there who also installed one of this know if this is the case?
Instead of plugging it directly to the OBD I went and installed it right underneath the steering wheel like the video in the link here
I just got one today and it took all of the 10minutes to install on my '22 GX
Works as promised
The hard part was getting the steering column trim back on
Old 08-30-22, 07:37 AM
  #321
nzvlnr
nzvlnr's Avatar
It looks like there is an option in the settings ( dealer activation) than can be executed to roll the windows up/down and open/close the side mirrors. The mirrors need to have the open close manual option already
I called the dealer and he said it would be 100 bucks to activate the window feature. !&*@
Does anyone have the code and or software needed to be able to turn this feature on ?
Vehicle Customizations / Lexus Personalized Settings (LPS) - ClubLexus - Lexus Forum Discussion
2eXceL (05-25-24)
Old 11-06-22, 07:36 PM
  #322
ScaldedDog
ScaldedDog's Avatar
I'm considering the Forten Kingdom 20-22 unit from post #320 for my '23 GX. Is it still causing the alarm to go off after the 10-minute remote start timer expires? I don't use remote start often, but that would be a pain.
Also, since the unit for the newer models add a physical interface for the module (the thing that looks like an OBDII port), does that mean the OEM OBDII port still functions normally?
Mark
2eXceL (05-25-24)
Old 04-19-23, 09:38 PM
  #323
easym0ney
3rd Gear
easym0ney's Avatar
Originally Posted by Piney1
I ordered the parts from Aliexpress, the folding actuators and the OBD plug in. Do I need the dash switch with the fold/unfold part to it? If I don’t care to ever fold and unfold them since the feature will be handled with the remote. Is that only necessary for doing it on-demand?
did it work without the on/off dash switch?
Old 04-20-23, 09:27 AM
  #324
Piney1
Piney1's Avatar
[QUOTEn=easym0ney;11490605]did it work without the on/off dash switch?[/QUOTE]
It did not and I’ve not gotten around to buying the needed mirrors w the needed frame.
Old 04-24-23, 05:15 PM
  #325
mikedallas
7th Gear
mikedallas's Avatar
I have had this one installed for about three months now. File this as the best $30 mod for the GX, right before the LED interior light upgrade. No battery drain, and awesome peace of mind knowing if I can see my mirrors folded from across the parking lot (or from our security cameras), the doors are locked.
https://www.aliexpress.us/item/22518...andl_shipto=US
Old 04-25-23, 03:16 AM
  #326
Piney1
Piney1's Avatar
Those are great. If it makes your windows roll down and roof open automatically, even in the rain, you’ll need to use TechStream to go in and reprogram the vehicle so that just the mirrors work with that.
Old 04-25-23, 04:09 AM
  #327
tntcandy
tntcandy's Avatar
I just ordered from Amazon -->
Amazon Amazon
I'm sure these are the same ones, just from US seller
Have not had a single issue since Sep 2021
Old 04-25-23, 07:04 AM
  #328
mikedallas
7th Gear
mikedallas's Avatar
My windows only roll down if I tap unlock on the remote three times. I guess you might need to jump into TechStream if those are the results you are getting.
2eXceL (05-25-24)
Old 05-02-23, 09:19 AM
  #329
bennero
8th Gear
bennero's Avatar
Did you install this? If so, any issue? I want to install on my 23 as well.
Thanks for your time!
Old 05-02-23, 10:15 AM
  #330
arkaa
3rd Gear
arkaa's Avatar
Ordered the 'WINSGO' one from AliExpress in Mar. Was on sale for $25, and there was a $4 coupon - so $21 with free shipping.
https://www.aliexpress.com/item/2251832643043428.html
Took 18 days for delivery. Installed it immediately in my 2019 GX, its been a month now and it has been working great. No issues. Probably the easiest & cheapest upgrade on the GX.
- Mirrors unfold on unlock
- Clicking unlock quickly 3 times in a row rolls down all windows
- Pressing and holding the unlock for a few seconds rolls down all windows & opens the sunroof
- Mirrors fold & all windows roll-up on lock. But sunroof, if open, does not close.
I wish there was a way to make it close the sunroof on lock. If anyone knows how it can be done, please tell. I guess there should be some option in TechStream to set that option.
2eXceL (05-25-24)
Quick Reply: Auto folding mirrors
