High Beam LED replacement...
Old 01-18-18, 03:51 PM
  #31
bbqsoup
bbqsoup's Avatar
Originally Posted by Acrad35751
VLEDs told me they will have a setup in mid-late February that should work perfectly with DRL/High beam setup on '10-'13 GX.
I assume this is the decoder----> " small DRL Control Box that will just plug in line between the factory bulb connector and the LED Headlight bulb."
A variant of this I assume but spendy compared to other options.
http://www.vleds.com/micro-9005.html
It does have a 30 Day 100% risk free guarantee so will probably try them out.. they are located about 50 miles north of me.
Wow, their lights look really nice, expensive but nice! LOL. I'm looking for some H11 replacement for my wife's 2014 Camry which still uses halogen and these look so good.
I'm curious of their "cheaper H11" are direct replacement for the GX fog light bulbs as well.
EDIT: When choosing DRL for the GX, I see these, anti flicker from the other Micro LEDs
http://www.vleds.com/shop-applicatio...hb3/lexus.html
Old 01-18-18, 04:26 PM
  #32
Acrad
Super Moderator
Acrad's Avatar
Received 3,638 Likes on 2,383 Posts
I had an existing support ticket open so asked them about the one listed above. It does look like what would be needed. Not sure on direct replacement but everything I have ordered from them in the past has been spot on for fit and never had a failure.
Old 01-18-18, 04:42 PM
  #33
Acrad
Super Moderator
Acrad's Avatar
They got back to me right away about that light kit.
"We have not tested our R4 Kit in the 2012 Lexus GX 460 and therefore can not guarantee that it will work. Our new 9005/DRL Kit should work for your Lexus GX 460 without any issues"
Old 01-20-18, 02:48 PM
  #34
bbqsoup
bbqsoup's Avatar
I installed the decoders today. It’s sending full power instead of half so it’s high beam all the time with DRL, the flicker is gone. I may have to adjust the light sensibility to have the low beam turn on sooner in Auto mode with these.
Old 01-20-18, 02:52 PM
  #35
Acrad
Super Moderator
Acrad's Avatar
Is it even too bright for daylight?
... you can tell when someone has their highs on even in daylight.
Old 01-20-18, 04:02 PM
  #36
bbqsoup
bbqsoup's Avatar
Yeah they are bright but not too bad during daytime.
Old 01-20-18, 04:10 PM
  #37
bbqsoup
bbqsoup's Avatar
Some pics. For some reason I couldn’t attach picture posting on iphone when replying/quoting a post, only in new reply (and it’s intermittent too)
btw, I was able to twist it enough to have the LEDs facing the side of the housing
Against the sun
With the sun
Acrad (01-20-18)
Old 01-20-18, 04:28 PM
  #38
Acrad
Super Moderator
Acrad's Avatar
That looks good!
EDIT: Good to know on being able to get lights twisted. If you get a chance can you report back on night-time again? Who knows maybe the slanted angle gives better light at night. :-)
Old 01-20-18, 08:36 PM
  #39
bbqsoup
bbqsoup's Avatar
That looks good!
I could see that it throw light a little further and maybe a little brighter.
Some low and high beam pics. They don't do the brightness justice and it is bright in person. You can hear the fan when the engine is off but not in the cabin when the car is on of when driving.
low+high
low
low+high
low
low+high
low
low+high
low
GB2011GX (01-22-18)
Old 01-22-18, 09:06 AM
  #40
GB2011GX
GB2011GX's Avatar
According to this chart, my 2011 GX 460 takes: H11 for DRL (low beam), 9005/HB3 for High Beam, and H11 for Fog.
Interesting that their only product shown is ALWAYS Nokia.
http://www.lightbulbs4cars.com/lexus%20bulb%20guide
Soup... how much was that decoder?
Old 01-22-18, 09:26 AM
  #41
bbqsoup
bbqsoup's Avatar
Update : the DRL is still flickering but very lightly and hard to see with naked eyes. But if you use iphone to video you would see it. I checked around and looks like all decoders are the same voltage.
In highbeam, there is no flickering.
GB2011GX, The decoders are about $16 but I’ve seen some are cheaper.
GB2011GX (01-22-18)
Old 01-22-18, 09:37 AM
  #42
GB2011GX
GB2011GX's Avatar
Thumbs up
Soup, you found a combo that works, so no re-inventing the wheel for me... Can you provide a link to those exact same decoders you purchased?
Many thanks in advance!
Old 01-22-18, 10:03 AM
  #43
bbqsoup
bbqsoup's Avatar
These are the ones I got
https://www.ebay.com/itm/LED-DRL-Dec...torefresh=true
The LEDs I purchased from Amazon have the polarity reversed.
GB2011GX (01-23-18)
Old 01-22-18, 10:41 AM
  #44
GB2011GX
GB2011GX's Avatar
My daughter replaced hers in her Tahoe a while back. This is what she used... No flicker and I do not like to be in front of her! The U3 design helps with positioning of the LED element.
Old 01-29-18, 05:36 PM
  #45
bbqsoup
bbqsoup's Avatar
To throw something new into the mix.
I was looking to replace the bulbs in my '06 Odyssey and came across a thread in the Odyclub forum where you can use HIR1 9011 (9005) bulbs in place of the standard 9005. The HIR1 produces about 2300LM and is considerably brighter than that of the stock 9005. The only different it you need to trim the tab just a bit to make them fit. So if you're looking for a brighter output while still wanting a proper DRL then this may be the way to go.
The Odyssey uses 9011 HIR1 (9005) for high just like the GX
I'm getting a pair of HIR2 9012 to install into my Odyssey and thinking of pick up a pair of 9011 HIR1 for the GX or Camry's highbeam.
Example of what to trim for the 9012
Here's the link from the Odyclub thread
http://www.odyclub.com/forums/52-200...t-bulbs-3.html
GB2011GX (01-31-18)
Quick Reply: High Beam LED replacement...
