I recently purchased a pre-owned 2016 Lexus GX 460. The car is fabulous with minor wear for the year with the exception of a damaged area to the leather in the rear passenger seat. The previous owner transported her grandchild and although she reportedly covered the seat with a cargo blanket, there is a very noticeable place where the leather appears worn. I would appreciate suggestions on how to repair the damage. I originally thought it was a stain but it appears the leather dye has wore off. Just not sure what to do about it. Thank you.
I believe the leather dye has been worn away from a car seat but I am not certain. Can anyone tell from the picture or has ever seen this happen? If so, how do I repair it?
I have purchased leather dye for my LS430 driver seat from this company.
Try woolite diluted 1:10 with water and a soft cloth. Do not rub it too hard as it will strip the clear coat that is sprayed on the seat at the factory.
I find the Chemical Guys leather cleaner and detailer products do a good job of cleaning up my interior. Same kind as yours, semi-aniline ecru leather. I'd suggest giving that a try before buying an entirely new part. Those things aren't cheap and the Chemical Guys stuff is pretty good at doing its job. It's fairly easy to get, too. Pretty popular brand. I got my stuff from Walmart during one of my US visits, and that was only because it's more expensive and harder to find in Kuwait.
Thanks Guys. Tried the above then went to a high end detailer who does ferrari ans they couldnt get the stain out either
They recommended someone who may airbrush /paint it
not sure if it will match or try to buy used
Ouch, it looks like seat cover made it worse. As an option, try a leather repair shop and see how much they would charge to get this back to brand a new condition, I've had to fix my seats and it cost about $500 for both front seats, i'm sure it will cost less for yours.
Looking for seat cover/re-upholstery ideas... Need 2011 Ecru lower covers/leather... I see some on eBay--anyone ever installed? Wonder how bad new bottoms will look against old uppers... are there any affordable aftermarket alternatives?
