2011 GX460 with Air suspension lift
Start looking into these posts (not sure if it is available in the US):
https://www.clublexus.com/forums/gx-...ml#post9984045
When you say not looking for anything huge, we have roughly 31" tires, you can realistically upgrade to 32" or 33" tires with a spacer lift (may rub depending on tire choice/tread pattern). You can go with aftermarket shocks and springs if you want better off road performance. You'll just need to figure out what you are going to do with your rear air bags, once you decide that, pick a kit to fit your needs.
HitchCrack
X20A
IS F (2008-2014)
03-04-11 05:14 AM
