Air Compressor Mount
Super Moderator
Can't say I have this need yet but if you have a ARB CKMTA12 or CKMA12 air compressor you can mount under hood above master cylinder.
http://www.sleeoffroad.com/products/products_air.htm
That is pretty cool. I personally carry a Viar 88P in the truck that can inflate a 33 tire in few minutes. I wonder if it works with other compressors too or just Arb.
I am sure it would work with other pumps as long as the pump will physically fit in that location. At the most you would need to just drill new mounting holes on the bracket for the compressor.
Super Moderator
Maybe even some heavy duty type rubber straps or a clamp of some type to keep removable if you still wanted that function
bluedurama
GX - 1st Gen (2003-2009)
03-02-16 11:09 AM
