Adding wide view and sideview camera support
Old 11-25-18, 07:03 PM
  #151
Ramacher
Ramacher's Avatar
Originally Posted by John00
Down in that area is where I shorted the pins to put it into reverse, but I didn't have the wiring to activate the monitor. Now on pause to see about the Tesla style tablet interface.
why did you short the pins to put it in reverse and is the wiring you're talking about the wiring I have?
Originally Posted by hzhao
Did you see this screen when you in reverse? The button (1) supposed to change the display mode with or without guide line.
I have no options when the reverse camera is shown. When the front and side cameras there's an option on the top left that seems to do nothing when i tap it.
Reverse camera
Front and passenger side cameras
Old 11-25-18, 07:49 PM
  #152
John00
John00's Avatar
It's been a couple of months, but I think it was that one there. Made the mirrors go down and reverse lights turn on.
2012 premium. I never did find the correct wiring diagram and since waiting for the tablet interface I haven't looked any more.
Old 11-25-18, 07:55 PM
  #153
hzhao
hzhao's Avatar
Uh.... Not even the blue fixed line on reverse? I have no idea what else to look for. Maybe other folks with Driver Support Package can offer some ideas.
The top option on front/side view will only be active when there is a camera in Driver side mirror, which in your case is correct
  #154
John00
John00's Avatar
I shorted the pins because at one time I was going to have a button to turn on the camera when not in reverse.
Old 11-25-18, 08:10 PM
  #155
John00
John00's Avatar
For location perspective, that connector is just barely visible in this pic (in the circle)
The following 2 users liked this post by John00:
Acrad (11-26-18), hzhao (11-26-18)
Old 01-06-19, 12:52 PM
  #156
Acrad
Super Moderator
Acrad's Avatar
Received 3,619 Likes on 2,370 Posts
I guess I didn't realized that 10-13 "Multi Terrain Monitor" optioned models outside of USA actually had direction lines as well and looking in lower left corner dynamic as well. "Multi Terrain Monitor" isn't the same as the Driver Support Package & cameras. It has 4 cameras and left camera comes into play while off road.
Here is an example from Russia.
Old 01-06-19, 02:37 PM
  #157
hzhao
hzhao's Avatar
For some unknown reasons, everything sold here has many options been eliminated, mostly die to some stupid regulation that was so out dated but no one wants to go through the hassle to change them. Such as driver side mirror has to be flat not curved, turn signals has to be initially certain rumination size which prevented most dynamic sequence turn signal setup, etc. I would assume some of those options and setups in someway and somehow ended up in gray area of regulations.
Old 02-07-19, 03:34 PM
  #158
r2m
r2m's Avatar
Don't you need a new steering wheel for the radar? Isn't there an extra button on the right hand side of the steering wheel for that?
Or can it be activated somewhere else?
Old 02-07-19, 04:36 PM
  #159
Acrad
Super Moderator
Acrad's Avatar
Correct... that is one part that is replaced.
Old 02-07-19, 04:41 PM
  #160
r2m
r2m's Avatar
Albeit, a very expensive part...
Old 02-07-19, 04:46 PM
  #161
Acrad
Super Moderator
Acrad's Avatar
The radar/distance sensor alone is over $2k.
The full Driver Support Package add-on to a '19 Luxury currently has MSRP of $2340
You see some used ones once in a while in the $700-$1000 range.
Old 02-07-19, 05:09 PM
  #162
r2m
r2m's Avatar
Yikes!!!
I'll just keep an eye oh the guy in front of me when in cruise control...
Old 03-01-19, 12:43 PM
  #163
Acrad
Super Moderator
Acrad's Avatar
Took a chance and lost.... :-( I should have researched far more...
I picked up a used AHB mirror from a '13 model.
I should have paid far closer attention to the obvious about the connectors for the mirror and actually took it apart first. If it plugged in I was gonna take the risk the BCM might still work with it. As you can see connectors different...
Wiring schematic made it look like only a few wires coming out of AHB model... well this one has 12. I'm curious to see what my official factory wiring harness book shows but that won't get here for another week.
[Original]
[AHB Model]
EDIT: I will hang onto the mirror considering I got it for less than 1/3 of new. Maybe over time I can piece together what is needed to get mod working.
PN: 87810-0WB70
Originally Posted by KJ6IRM
Thanks!
It looks like one would have to replace two computers in order to get the auto high beams working. I think that will be a project for another time if ever. Now just going to concentrate on getting RDCC and the cameras working.
89220-6A151
Computer, Multiplex Network Body
LIGHT CONTROL SYSTEM-W(CONLIGHT & AUTOMATIC HIGH BEAM SYSTEM)
and
89940-60080
Computer Assy, Headlamp Swivel
HEADLAMP-AFS & DISCHARGE&LIGHT CONTROL SYSTEM-W(CONLIGHT & AUTOMATIC HIGH BEAM SYSTEM)
Old 03-01-19, 05:31 PM
  #164
bbqsoup
bbqsoup's Avatar
That's a bummer...it would be a cool mod for sure.
Acrad (03-01-19)
Old 03-01-19, 05:45 PM
  #165
Acrad
Super Moderator
Acrad's Avatar
I haven't given up. I have a Lexus '12 FSM wiring diagram book that is supposed to show up tomorrow. It seems there are few wires to get this working but still not sure on the BSM or AFS modules whether it will work. Crawl mod probably pushed me into being a little less concerned about compatibility as at one point skid ECU was a concern which turned out to being moot.
Quick Reply: Adding wide view and sideview camera support
