Thumping noise with hard acceleration
2017 Gx with 20K miles. Noticed that when I accelerate hard from a stop position, i hear what is a thump toward back of car. Sometimes it sounds like real axel engaging, other times its like something is rolling into back of car from the hard acceleration. It comes about 1/4 second after accelerating. Is that normal?
Gxkenl (03-17-18)
Rear driveshaft? It's been common in late model Toyotas to have a driveshaft thump when the slip yoke isn't properly lubricated with grease. Toyota supposed "fixed" it, but it could be your issue. If you service your own GX, then try pumping some moly grease into the slip yoke. If not, then ask your servicing dealer to do lube the driveshaft, and let them know you are getting a clunk that might be the driveshaft slipping.
It's not a problem of concern (assuming this is your issue) - just an annoyance.
Super Moderator
+1 ....
If reproducible every time you probably want to take into the dealer since under warranty
Good insight as always. Its got 20K and under warranty and it is reproducible so dealer look a good idea. I will check for rolling ***** or cans in the back of course. One thing of note.... had a flat tire on back passenger last month and they struggled getting the spare tire off. Will make sure everything is put away properly.
GB2011GX (03-16-18)
Super Moderator
Originally Posted by sjarnot
Were you able to get any resolution with that noise? I bought a 2018 gx460 with only 7k miles and have the same issue!
Super Moderator
Perhaps zerks weren't adequately lubricated from factory? There are 6 zerks
Zerks
(1) Front Slide Yoke
(1) Rear Slide Yoke
(2) Up front one for each u-joint/spider
(2) Two each u-joint/spider in rear
S - Y -S (Transfer Case) S - Y - S
REAR DIFF <-> U-Joint/Spider <-> Rear Slide Yoke <-> U-Joint/Spider <-> TRANSFER CASE <-> U-Joint/Spider <-> Front Slide Yoke <-> U-Joint/Spider <-> FRONT DIFF
Zerks
(1) Rear Slide Yoke
My son started driving the truck more often now and I sat in the back seat and every time he accelerated I have like hump sound (not a bad bearing) but like a rear end or axel. Anyone with this sound?
plee542
GX - 1st Gen (2004-2009)
26
12-03-03 06:40 PM
